I have a glo warm propane heater. The pilot won’t light, nothing will light. I changed the hoses and regulator, still won’t light. Any ideas
6ya staff
SOURCE:
Mike Waldron
  • 1019 Answers
SOURCE: glo warm heater
I,d suggest that you have either a case seal Damaged, allowing air into the casing.
Also possible fault may lie within the Flue air pressure Valve/Switch If applicable.
The heater/Boiler will have certain conditions to meet.
The Fan/flue switch ( Pressure switch. Will be designed to speed up the fan, before firing the main Burner.
As for the Noises, i,d suggest that the boiler is whats commonly known or reffered to As Kettling. Which usually indicates Overheating. This would cause the main-burner to distinguish as a fail safe.
Recommendations:- De-scale the heater, with a commercial descaler. Thoroughly flush the System. Then re-fill with required Amount Of Commisioning Fluid. i.e Fernox Or Sentinel et,c.
Also get the Fan/flue checked out for correct running speeds.
Mike @ compurepair.
Posted on Mar 16, 2008
Anonymous
SOURCE: glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Posted on Nov 22, 2008
Anonymous
  • 92 Answers
SOURCE: Glo Warm propane heater won't light
There is really not a lot to go wrong with the heater itself so my first guess would be that the regulator is bad, not letting the proper amount of gas through. You can check it for leaks with a bottlee of soapy water but even if you don't see a leak there is a rubber gasket inside with a pressure spring that is probably bad.
Posted on Feb 04, 2009
Anonymous
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
Paul Carew
  • 3476 Answers
SOURCE: I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Posted on Nov 30, 2010
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
My glo-warm wall mount heater pilot light will not light. I tried the ignitor, saw blue spark , and nothing. I also tried using a lighter, I got it to light barely once and that was it. I can't smell any...
Without the model number of the heater it is hard to give an accurate answer but I will give you some suggestions.
I would start with cleaning the pilot ODS assembly.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
I would check the regulator on the heater...if it is propane these gas get raw gases in the regulator and cause the unit not to pressure up correctly.
Give these items a try first before replacing any parts.
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Desa International Blower Glow Warm Wall...
Nov 29, 2010 | Desa International GWRP16 16,000BTU LP Gas...
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
I have a small dyna glo that takes a propane cyclinder. i bought the hose to hook up to a 20 pound propane tank. every time the tank gets below a half tank the pilot light blows out and heater cuts off i...
There may be dust building up in the ODS safety pilot assembly. The simplest way toresolve this is to flish the pilot with rust buster. Why rustbuster? It has a telescoping tube that makes it easy to direct the squirt into the pilot. Let it dry then retry. You will be amazed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
May 04, 2009 | Desa International Blower Glow Warm Wall...
Feb 04, 2009 | Desa International GWP20T GLOWARM Wall...
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Glo warm?
Oct 19, 2008 | Desa International Blower Glow Warm Wall...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
