Question about Sharp Televison & Video
Why does a sharp 19n-m100s tv comes on and after about five minutes it cuts off and it doesn't power up until power cord is plugged out and plugged back in
    Top Expert:
  • Sharp Master
  • 10,371 Answers
Check power settings see if on delay if not possible bad power board
Posted on Oct 22, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Power problem
OMG!! I had the exact same problem! I unplugged the TV to paint and it stopped working with a flashing green button. I ran my fingers along the bottom of the screen and it actually worked.. wow THANKS A TON!!!
Posted on Jul 06, 2008
Anonymous
SOURCE: my 42 inch plasma wont turn back on after power cut?
Go buy a CRT television for $200 and chunk that HD TV. All of them are made in China with the same poor quality. Why seemingly smart Americans would pay good money for such junk is beyond me.  The LCDs are a cash cow for the monitor and TV industry as they are well aware the inverter boards will fail within 3 years time.  The old CRT tvs will work for the next 15 - 20 years without failure. Get you a good ole 36 in sony black stripe tube and kiss the LCD crowd good by.
Posted on Nov 28, 2008
Sheldon Dedek
  • 909 Answers
SOURCE: E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Posted on Aug 25, 2009
Chi Chu
  • 8457 Answers
SOURCE: I have a Sharp LC-37SH20U flat screen TV. The
The main video backlight board is dead,must be replaced.
Posted on Oct 19, 2009
toolkits
Sanyade Akinwale
  • 1099 Answers
SOURCE: My LG 42"tv shuts off by it self
hello, The best way to fix this is by opening the back cover of the television set.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Posted on May 20, 2010
Model LC-C4677UN. Why does it keep turning off?
** If you don't know what your doing back there, probably best not to go poking around. Power supply capacitors can bite hard and unmercifully, even when they've been unplugged for days. If you know how to safely discharge them, then do this before you touch anything. Until this is done, Keep one hand behind your back at all times, and this is no joke. To locate the power supply, follow the connections from the AC cord that go into the TV. The board that these wires are connected to is the power supply. Plenty of videos online about how to locate bad capacitors. Which is a very common problem in some tv's.
Feb 23, 2016 | Sharp Aquos Televison & Video
Can i get the flyback # sharp tv model no 19r-m100s
It is available. There should be a number on it as its part number, and you should mention this for buying a new one. Try www.ebay.com/
Oct 21, 2014 | Sharp 19R-M100 19" TV
Please tell me how to turn off tamper proof on my Sharp tv/vcr combo without original remote. The remote I have doesn't have a toggle button. Thank You!
As you know, the Tamper Proof function is activated and de-activated holding the Toggle/Source/Input button for about five seconds.
If your universal remote does not have this button (under any name), then try all buttons.
Try also disconnecting power cord for five minutes, this will reset most TV functions.
If still no luck, then you will need a different remote to get rid of the function.
Try all buttons on your remote. If the Tamper Proof had been activated using this remote with this codes, then it can be turned off using the same remote.
Dec 12, 2009 | Sharp VT-G14 14 in. TV/VCR Combo
After 4 years of great service my tv cuts of by itself. I unplug for a few minutes and plug it back in and it plays for 30 minutes and cuts off again
Your power supply is going. It is probably a capacitor that has dried out or some other overheating problem.
Tim
Nov 26, 2009 | Sharp 25N-M100 25" TV
Aug 23, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
Is this TV digital ready?
No, this TV does not appear to be digital ready.  There is no mention of digital capability in a review in eBay reviews.  You will need a DTV converter or cable box to view digital TV on the this set.
May 20, 2009 | Sharp 19N-M100 19" TV
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
Televison & Video Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
