My apartment building got struck by lightning and my tv won't turn on. I have no standby light and after watching some of your videos on youtube .
I opened up my set and I don't have the green heart beat light at all. Is this a power board issue or the t-con/logic board. Also it appears that the spike may have come through the HDMI cable since that port no longer works on my cable box; had to use component connection for a different tv.
    Top Expert:
  • Televison & ... Master
  • 10,371 Answers
Bad power board
Posted on Oct 22, 2019
  • Donald Moulder Oct 26, 2019
    Replaced power board. Still have nothing. No standby no green light in back of set.
6ya staff
SOURCE:
Anonymous
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
micromaster
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
Anonymous
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
Anonymous
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
Anonymous
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
My Samsung smart tv won’t turn on
First, I'm not a Sam Sung representative.
* check your warranty. Call for service.
*** The following is for information only.***
* Common Sam Sung TV issues; https://www.youtube.com/watch?v=9WOyR_UaBDM
* Customer's solution (from Samsung); https://www.youtube.com/watch?v=d5WwsbATsy4
* Lady's solution ; https://www.youtube.com/watch?v=rRjbxpoQQBE
* Still have problems? Call for service.
Aloha, ukeboy57
PS, The following links are for repairs that will VOID any warranty.
* Customer's repair (very Technical! Not warnings.); https://www.youtube.com/watch?v=wEWzYLaKdgU
* Another customer repair; https://www.youtube.com/watch?v=T6FmYo1fACk
* Standby like on but won't turn on; https://www.youtube.com/watch?v=tqvjkq5vSmw
* Clicks but not turning on; https://www.youtube.com/watch?v=egNSzoH4tRc
* No click at all; https://www.youtube.com/watch?v=q1cPPA9Q5yw
Jul 23, 2018 | Samsung Televison & Video
How do I diagnose and fix an LCD HDTV whose screen will not come on because of possible lightning strike?
needs circuit testing doubt you would actualy be able to see any damage to circuit boards doesn't take much of a power surge to knock one out tv engineer needed
Aug 25, 2015 | Televison & Video
Sony bravia lcd won't power on after lightning strike
I am sure the tv is shot from the surge but you can check a few things. I would take the tv apart and test the power supply first. Look for obvious burn damage throughout the boards. If there is a blackened one (prob video board) then you can try to replace that. Don't worry about taking this apart and breaking it further. In this case it can only get better for you.
Oct 06, 2012 | Sony BRAVIA KDL-46EX400 46" LCD TV
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 08, 2010 | Insignia NS-LCD22-09 LCD HDTV
Lighting struck the apartment about a week ago, tv was plugged in when lighting struck apartment. Tv does not turn on anymore.
Best to take it to a repair centre as lightning damage can cause either minor fault such as an internal fuse blown or major problems that would make it uneconomical to repair. Ask for an estimate for the cost to repair.
Oct 01, 2009 | Broksonic CTGV-5463TCT TV
I have a 58'' HP Pavillion Projection screen TV. It was struck by lightning. the power cord is good. It will not turn on at all, no fans running, etc. What do you think I will have to fix?
As u have just said that it was struck by lightning the only way to get the TV back working is to replace burnt items on the moterboard .becouse lightning must have demaged some components on the power supply, if possible i would preffer a new power supply board
Aug 31, 2009 | Televison & Video
Onkyo Struck by Lighting
before taking it to an authorized center , check the main power supply section for any fuse or circuit breaker . good luck AJ
May 07, 2009 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
Broken TV in building hit by lightning
hi
depending on the intensity of the lightning strike.Your tv may have blown components in the power supply section of the motherboard.
unfortunately its very very difficult to acertain level of damage unless its looked at by a trained tech/engineer
cheers
Jun 16, 2008 | Televison & Video
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
