Question about Slendertone Fortex
My Slendertone doesn't work properly, it will not set the intensity of pulses. I have tried every button pushing alternative I could think of. How do I return it for repair?
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
2004 Chevy Tahoe, Horn doesn't work.
The button on you steering wheel is the problem, try to open it up and pull the spring just a little bit. I think you have used it too much ;)
Jun 16, 2012 | 2004 Chevrolet Tahoe
2002 Olds Intrigue ...sometimes the wipers start by themselves with the switch in the off position. The only way to shut them off is to push the washer button.(sometimes takes 3 or 4 tries).-do you think...
usually its both the switch and the pulse usually go bad at the same time but u can start with wiper motor with pulse board try rockauto.comtheyre best for parts
Sep 14, 2011 | Oldsmobile Intrigue Cars & Trucks
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
May 21, 2011 | Health & Beauty
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Jan 13, 2010 | Slendertone Fortex
Set time and date
I picked up a cid 244w phone at goodwill because it will work with the power out. With a lot of fiddling around I found that if you push the erase button and hold it, then push the review arrow down button the menu starts. It starts with Contrast then to language, area code, date and time, and lastly tone or pulse.Set it to tone,Pulse is the old rotary dial phones. You scroll through the menu by pushing the erase button and change things with the review up and down buttons. If you wait too long to change something the menu automatically advances. If the item you want to change passes by just start over. Good luck, I hope this helps
Mar 15, 2008 | Conairphone CID 244
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Slendertone Fortex Logo
32 people viewed this question
Top Slendertone Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
