SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
SOURCE: WHIRLPOOL MODEL NO. ET8CHMXKBO4: WATER COLLECTING
The likely problem is the drain leading from freezer to bottom of refrigerator is clogged or stopped up. I will send you to another link so you can see and get pictures and answers to help you solve this.
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Let me know if this help, Sea Breeze
SOURCE: Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
SOURCE: built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
[email protected]
67005154 or 1071263 Water Control Valve
SOURCE: Leaking water on floor
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Hi
Look on the ceiling in the back by the compressor do you see a small hose on the ceiling. There's an access panel at the lower right corner. That's where it is ,there's a drain pan just under the hose remove that panel its right there.
Also check this link to have a detailed idea:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
