Hi, if it still hard to push with the scooter turned off, you maybe looking at the brake not releasing 100%, make sure any manual brakes are releasing okay.
Now if the magnetic brake situated on the side of the motor is not releasing 100% (clicking sound ) that will cause the problem you describe, it will get hot ,,, because of the fiction when in use ..
get some wd40 or better gt85 and spray in the gap between the motor and brake, get the wheel of the ground safely and run the scooter, the spray will help the brake release if it's sticking , BUT WARNING , REMEMBER you LUBRICATED a BRAKE so it will slip for a while ..
The brake is a electro magnet so it may be that it need to be replaced, at worse it a controller fault.
Regards
Rob
SOURCE: Canon EOS Digital Rebel
Hi
If your camera is less than a year old then you should try sending it in to Canon for repair. If the camera is more than a year old you will have to take care of the repair yourself. If you take the camera to a 'camera shop' they will tell you its $200 to do the repair, but I know a place that will do it for MUCH cheaper Google: Darntoothysam com.
The fuse on the PCB (Printed Circuit Board) has most likely blown to save the board from being shorted and ruined. All you need to do is replace the fuse and you should be good to go! If you are skilled with fixing things and pay close attention to detail you can do it yourself.
If you don't want to do it, I know of a digital camera repair shop that can help you out. (Google: Darntoothysam) I don't think we have a no-power repair listed in the store, but we can get it added for you, no problem. We have a certified Canon, Nikon and Fuji tech do this repair for us, he has repaired hundreds of cameras for us over the past 5 years and does a great job.
If we can help with the repair, please let us know. Good luck from Darntoothysam com
Thomas
SOURCE: I have a merit 4 wheel scooter I replaced the
sounds like the engager (paddle assy.) needs to be replaced
SOURCE: Motor wont run
I wish I could help but I have the same problem that you do. If you figure it out please let me knwo and I will do likewise if you give me your e-mail
[email protected]
SOURCE: When to recharge batter
Generally with rechageable batteries, the first charge is critical for setting the life and capacity.
The strict rules are:
1) on the first charge, fully charge the battery without interuption for the full amount of time, (Usually 8 hours).
2) on the first use of the battery, fully discharge the battery without recharging it, At All.
These two rules set the charge capacity for the battery. To get the longest life and fullest charge out of your battery, don't fail to be patient with these.
After the first complete charge and complete discharge cycle, you may place your device on the charger whenever it's not in use. Eventually the battery will hold a stronger charge for a longer time, usually after three or four good uses. The battery should work well for about three or four years before you need to replace it.
Failing the two rules for the first charge and discharge, will require you to settle with lower performance of your device, or immediate replacement of your battery.
This information is usually misleading since buying more accessories, or another vaccum is in the best interests of the manufacturer.
Note: Sometimes rechargeable batteries do have manufacturing defects, and can be replaced under warranty of quality of workmanship. Since the battery cannot be tested before it's sold, getting a warrantee replacement is usually the best option in the event that your machine isn't performing properly.
SOURCE: I have new batteries in my merits power chair but
Bad Charger or bad batteres that all it can be Hope this Helps
