Question about Radio Communications
I have a soundlogic Bluetooth stereo headset and it's not turning on no matter how long I charge it.
6ya staff
SOURCE:
Anonymous
  • 51 Answers
SOURCE: Bluetooth Stereo headphones
according to the specs ive read these are the bluetooth profiles supported by your phone :
Bluetooth® Supported Profiles: dial-up networking, headset, hands-free, file transfer, imaging, printing, JSR-82
copied directly from motorola website........so in other words your phone does not support the bluetooth stereo profile.....so the headset may function as an earpiece but music play wont be possible
Posted on Dec 13, 2007
Anonymous
SOURCE: Lg Prada and Voyager 855 headset
the new headset is the updated version with better softwhere on it try the carphone warehouse they might have the new ones in stock
Posted on Dec 29, 2007
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: The Motorola H800 bluetooth headset doesn't charge or turn on. While charging it just displays blinking green light
open and, replace the rechargeable batteries
Posted on May 29, 2009
Anonymous
  • 5 Answers
SOURCE: I have a H270 Bluetooth headset. I charged it
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
SOURCE: HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
Posted on May 20, 2010
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
Bluetooth paired but not connected?
There are several kinds of Bluetooth Profiles. If you're only looking to send and receive phone phone calls, A Bluetooth headset only needs a Hands Free Profile or HFP.
The EM227 cannot be used as a stereo headset because a different Bluetooth Profile is required. If this is what you're intending to use it for, You may want to invest in Bluetooth enable Studio Headphones.
Try these steps to Troubleshoot the issue:
1. Make sure that your EM227 has been fully charged. the User Guide suggests that you charge the Headset for at least 5 hours before you use it for the 1st time.
2. Go to your device's Bluetooth Settings and scan for nearby devices.
3. Turn ON your EM227 Bluetooth Headset and place it in pairing mode. The Bluetooth indicator light will flash RED and BLUE.
Don't Forget to keep your Bluetooth Headset and your device within 3 feet of each other.
4. If your device asks for a Pass Code, try entering "0000" ( Four Zeroes)
Once you've paired the device, the LED indicator should now blink as a steady Blue light. Try making a test call.
Remember, The EM227 was only designed for Hands free calling ONLY.
Mar 15, 2013 | Emerson Radio Communications
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Good luck from Headsets Direct!
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
Will not turn on
First make that it is charged completely, If it is not charging it may have a loose wire or connection somewhere. Go through the trouble shooting in the user guide and it may have an answer for you.
Feb 15, 2011 | Plantronics Backbeat 903 Bluetooth...
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Mar 04, 2009 | Plantronics Stereo Earbud Headset for Use...
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
