SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
SOURCE: I need a manual on
ok here is the link , the manual is $28.95 and it is a parts manual , but if you scroll down the page they have a contact phone number that i would call . they should have a owners manual .
http://www.ssbtractor.com/tractor_manual_display.cgi?m=Massey%20Ferguson&o=MF%20424%20Grain%20Drill
