SOURCE: johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
SOURCE: is the 1973 johnson 25h.p.outboard engine 2 or 4
It's two-stroke. You need to mix oil with your gasoline to provide adequate lubrication.
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
SOURCE: water pump not working on
sounds like you need a new water pump impeller.
to access the impeller the bottom of the motor needs to be unbolted and the impeller is fitted to the shaft, it is keyed so it only goes on one way. ( impeller kits will come with new gaskets,grease.O-rings and a new key ). re-bolt the lower unit and test.
c...
