Question about The Watches
I have a SSC376P9 coutura perpetual calender. The date changes at the wrong time. It's about 19:30 and not midnight. Anyone have this problem or know of a fix?
6ya staff
SOURCE:
Anonymous
SOURCE: date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
Posted on Apr 17, 2008
Anonymous
  • 26 Answers
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Posted on Jan 03, 2009
Anonymous
  • 26 Answers
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Posted on Jan 06, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href="http://www.seikowatches.com/technology/kinetic/index.html">http://www.seikowatches.com/technology/kinetic/index.html</a><br /> Best regards.
Aug 25, 2010 | Seiko Premier KineticĀ® Perpetual Watch for...
I bought this watch citizen BL5334-04E year ago,
Mechanically operated date changes occur at 12 O'clock. If your watch thinks it is midnight when it is noon then it will change date.
The solution is to wind your watch on 12 hours.
Apr 17, 2010 | Citizen Eco Drive Perpetual Calendar...
Tag Heuer - Aquaracer automatic (Day/ Date)
Actually in the realm of things that is close to midnight. But if you want this changed you will have to take it to a watch repair person because the movement will have to be taken out of the watch and the hands pulled and rest to change when the calender flips over. When I set up watches i usually have the day/date flip after 2 am so that most people never see it change ( because they are asleep lol)
Jul 31, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Perpetual Calendar 100M, Ineed the instruction
Follow this link and click on OPERATIONAL GUIDE.
http://www.seikousa.com/#FAQ
Rate, please.
Jul 29, 2009 | Seiko Coutura Perpetual Calendar Watch
After replacing battery cannot set mo/day/date
I have the same problem. Watch stores are NO help. Does someone have an answer that works?
Jun 10, 2009 | Seiko SLL086 Watch
Problems setting my citizen eco-drive perpetual calender
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Apr 29, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
How to adjust day date on older rolex perpetual day date watch
Mar 06, 2009 | Rolex Datejust SS
Watch
You should be able to pull the crown out 1/2 way and turn the crown clock-wise and you should hear a click and the calender should move one day. Don't change when the hands when the time is between 10 and 2 , just manually move the hands past that time , and re-set afterwards. If that dosn't work let me know ,.There are other types of those watches , but the way I told you is the most common.
Jul 07, 2008 | Citizen Eco Drive Perpetual Calendar Watch...
Setting the time
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Sep 23, 2007 | Rolex Daytona 116520 Wrist Watch
Watches Logo
Top The Watches Experts
 Larry
Larry
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Watch Expert? Answer questions, earn points and help others
