Question about LG Televison & Video
My lg tv got laid down upon moving it now when turned on it has 2 lines that run down it how can I get the lines out
4 Suggested Answers
6ya staff
SOURCE:
romsky79
rommel dadulla
  • 822 Answers
SOURCE: Rolling thick black horizonal lines come up after
check secondary power supply there is a budged capacitors.
Posted on Jun 04, 2009
Mark
  • 403 Answers
SOURCE: I have a 6 mo
start hunting down your warrenty info before you do anything. If you try to repair own your own you will void it at this point
Posted on Mar 24, 2011
ekcnoel
Noel Jucutan
  • 998 Answers
SOURCE: tv was moved and laid
The problem of your tv. is the degauzer. Try to change the location of your tv, and be sure that the surrounding of your tv has no magnetic interference, like speaker.
Posted on Jun 08, 2011
Samsung tv m#Un60eh6003fxza has a horizontal line through it. The line appeared after a move. My question is, is it repairable?
IF it was laid down flat when it was moved, the lcd bounced and broke. If it was not, the cables inside and the connections need to be checked.
Mar 09, 2016 | Samsung Televison & Video
Why vertical lines on half of screen after moving Proscan 39" LED TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 14, 2014 | Proscan 32LB30QD 32 in. LCD TV
How do I attach the tv stand to a 40 inch Coby television?
This requires some care---set will have to be laid face down--the screen unit or display panel is EXTREMELY fragile---the set must be laid down so the entire frame around the screen is supported and no pressure is exerted on the actual screen! One wrong move or downward pressure can damage/destroy the screen.
The base is attached with several bolts that come with the set--exact length and thread type is critical. They may all be same or different lengths. Line them all up and tighten with hand--snug them down evenly with a tool---NO downward pressure on screen when doing this.
If have lost or do not have the bolts contact the maker who will tell you size, thread type and number of bolts.
Carefully when done lift set upright.
Apr 17, 2012 | Coby TF-TV3217 32 in. LCD TV
How to transfer LG cyon 2MP camera photos to computer
1. Connect your LG Cyon to your computer via it's USB cable.
2. Upon receiving a "USB Connected" notification atop the Notification bar, drag the bar down and select "USB Connected."
3. Now select the option corresponding to "Turn On USB Storage" or connect as "Mass Storage Device"
You should now see a new flash drive or storage device connected to your computer. Browse/Move/Copy/Delete files (including photos) as you would with any other flash drive or thumb stick.
Sep 25, 2011 | LG Cyon
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
Sears upright freezer will not come on after a move. Worked fine when we left the old place. Model 253.9244410
Sometimes when you move these, they hydraulic in the line if they were laid on it's side to move. Time is all it needs in this case- about 24 hrs. If it was not laid down, pull the back cover off the freezer and look carefully for loose wires. There will probably be a wire off either there or behind your temperature control.
Apr 23, 2010 | Freezers
We move my refrigerator and it was laid down for about 2 hours we plug it up when we got home now it won't get cold, how long will it take to start getting cold it been about 2 days now
It shuld never be layed down for transport or storage. 2 Hours is not a long time but you should have left it upright overnight before plugging in. turn it off for 24 hours. When you restart it it should be cooling in a few hours and at normal temp in 24-48. If not you may have damaged the compressor. (Assuming you hear it running)
Eric
Dec 23, 2009 | Kenmore Refrigerators
Laid tv face down and then set it up and the tv will not turn on.
if you bought it new and laid it down you have to wait at least 10 min before plugging it in or doing anything with it kinda like the fridg thing
unplug it and see if the store will replace it
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Sony FWD-50PX3 50 in. Plasma TV
Televison & Video Logo
19 people viewed this question
Ekse
RONALD CARTER JR
