Heating & Cooling Logo
Ricky Courtier Posted on Oct 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Duracraft CZ 308 heater keeps running. I have the thermostat set at 60 degrees but it doesn't stop running. It gets very warm in my trailer
Steve Pack
Level 3:
  • Heating & Co... Master 7,120 Answers
  • Posted on Oct 20, 2019
Steve Pack
Level 3:
Answers
7120
Questions
Helped
2270698
Points
27849
You need to stop using the heater, , the thermostat is bad and there is a risk of a fire, and no repair parts. Replacement heaters range $20-40.. Personally I would look at a different brand.
5 Related Answers
Anonymous
  • 72 Answers
  • Posted on Mar 03, 2007
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Anonymous
  • 1420 Answers
  • Posted on Nov 26, 2007
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
A
Anonymous
  • Posted on Mar 10, 2008
SOURCE: Rinnai rce-606tra II -- temperature is wrong
move thermister probe higher on back of unit
Anonymous
  • 700 Answers
  • Posted on Jan 25, 2009
SOURCE: Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Anonymous
  • Posted on Nov 02, 2011
SOURCE: I have a CZ 600 duracraft heater and it stopped
does the light on the switch come on?
I am looking for a replacement electric motor for a CZ1200 Duracraft Fan heater
duracraft model cz 1200 Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags
Jan 3, 2010 - Duracraft CZ 600 oil filled fanned portable heater and has two switch on end for different watt ... It is white portable electric,but it has oil in it, do . ... looking for replacement parts for a Duracraft model s6436 sander I am looking for a ... I need replacement moter for Duracraft Model DS1600 fan can I get a replacement motor? Where can I find parts for a Duracraft window fan ...
Aug 16, 2010
Duracraft User Manual
Sep 24, 2009
duracraft fan parts Questions & Answers (with Pictures)
Sep 4, 2009
SOLVED: Can't get at the fan to clean
Apr 14, 2008
More results from www.fixya.com
1helpful
2answers
My forced air heater in the bathroom keeps going on and off when it reaches the set degree. Is the heater the problem or the thermostat.
Try setting the Thermostat to the highest temp and see if it keeps running. If temp goes to the max it is the Thermostat if it stops prior to the thermostat setting it is the heater!
2answers
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Cz 500 shuts off and comes back on in about 5 minutes. is this a correct procedure.
Heaters have
)Tip over switch If the heater is thermostatically controlled then what you may have is the thermostat cycling just as a central heating system in your home. When heater reaches the temp you set it shuts off, then comes back on when temp drops several degrees below setting. Yes, It is normal. Ned
2)Thermostat
2answers
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Top Heating & Cooling Experts
Paul Carew
john h
