How replace the cutting line?
Possilbly similar model manual. Includes phone number for contact for assistance.
https://www.aldi.us/en/about-aldi/warranties-manuals/warranties-detail/sis/si/gardenline-cordless-trimmer/
SOURCE: Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: gt-2000 type1-e need line spool
THE NEWER STYLE ECHO HEADS WILL REPLACE THE OLDER STYLE. THIS MAYBE THE ONLY SOLUTION
SOURCE: Replacement of Cutting Line! How to do? anneodello
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
