Question about Vacuums
Euroflex monster makes humming sound no steam
3 Suggested Answers
6ya staff
SOURCE:
Azrael SRL
  • 11800 Answers
SOURCE: My euroflex monster 1200 steam
I'm assuming that you have checked the water inlet at the bottom and steam spout for lime or other deposits that can clog them - and cleaned them if necessary.
The steam is generated by the boiling of a small amount of water then the pumping of an additional amount of water in the steam spout. In your case the valve that controls the steam is defective.
There are no replacement parts for this unit - it's a service-free device: if something breaks inside it you just junk it and get a new one. If you want to try to fix it you will have to crack open the casing of the boiler (glued in there) access and replace the valve and glue it back together. It's a long and fiddly job for which you will need the spare parts recovered from another defective unit.
Posted on Jul 01, 2011
Dan Apthorp
  • 2824 Answers
SOURCE: No steam created with power light on
Sounds like your heater is shot. Probably needs replacing.
Posted on Dec 04, 2014
My quicksteamer just quit runnng. It makes a humming sound.
Maybe it got tired of running and sat down to rest. It may enjoy the rest so much that it's humming now. ( humor ) ... Sorry to tell you but most steamers don't last very long, it's probably done it's last steaming.
Jun 28, 2017 | Vacuums
Dec 03, 2014 | Euroflex Monster SC60 Multi-Surface Steam...
I have not used the machine for a while. When I did, a thick pasty substance emitted from the bottom steam vents onto the pas when steaming the floor. What does this mean and how do I correct?
Run a little vineagar and water solution through it. Then all you should run in the machine is distilled water so you dont get that residue and mineral build up on the heating element.
Jan 27, 2014 | Euroflex Monster Floor Steamer
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
