Infrared heater model GD9315BCW-5B stopped. We think it may have overheated.We turned off power withe reemote, but we have not turned off power on back of unit. What should we do?
3 Suggested Answers
6ya staff
SOURCE:
zatamite
SOURCE: i have life smart infrared
The thermostat needs to be replaced. The Company sent the replacement part for free. The also said they would send the instructions to fix it, but they did not. I am looking for instructions online. ;-(
Posted on Mar 13, 2011
Pete O
  • 17 Answers
SOURCE: Dayton 3E133 Infrared heater Unit using natural
Here's a link to the manual:
Posted on Dec 20, 2013
My 2 person zen awakening infrared sauna. The wire from the fuse going to the board with all of the wires attached has burned up. What to do?
possible loose wire caused overheating or motor or heater element overheated or shorted or bad ground also make sure power ok under power will overheat
Nov 11, 2017 | Pool & Spa
Tip
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
source
http://truckmanual.weebly.com/scania-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
West point infrared heater makes a loud buzzing sound when truned on
What does this have to do with PC laptops ??? Please post in correct category.
Dec 18, 2013 | Computers & Internet
The pilot light goes out when I turn the gas control know to on
Clean the flame sensor, thermocouple, or power pile located on the pilot with steel wool.
Nov 23, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heater Core replacement
first, check the coolant level and add if its low..check for accidental ac turn-on at the controlls..then its an issue with the controls themselves provided the water pump is good..there are baffle doors that are controlled reemotely in the dash and one of these couldd be not functioning or blocked by debris like a penny sliding into the defrost vent will jam the door and keep it from working...check these and see...good luck..
Jan 15, 2013 | 1998 Mercury Mystique
No heat on my 1999 jeep grand cherokee and overheating
Stop leak can cause the radiator ports to get clogged. But if your car isn't getting heat, it's probably your heater core. The heater core is usually burried in the firewall between the engine and where you or your passenger put your feet
Oct 18, 2017 | 2000 Jeep Grand Cherokee
I've replaced igniter/sensor on my dayton 3E132 infrared heater,will light but runs for a while and shuts down,also do you need it hooked up to a thermostat
Yes, it should be hooked to a millivolt wall thermostat. Doing that should solve your problem (overheating). However, the millivolt wiring can be no longer than 10 ft.
Feb 06, 2011 | Dayton (3E132) InfraRed Heater
MY heater So noisy
grease the bearings before you burn your house down.
Jan 04, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
