The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
if you haven't any error message then you may have a problem in laser shutter, check and reseat your catrtidge, or you have a problem in your DC Controller
you must clean separation roller whit wet cloth or alcohol.
Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean
Good luck.
P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
