USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! 1-85O-8I2-4OO9.{+1-8OO-8O3-1O69 {1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697
I AM COMPILING A LIST OF ALL SPAM NUMBERS ON FIXYA WHICH WILL BE POSTED IN MANY MESSAGE BOARDS WORLDWIDE
6ya staff
SOURCE:
Simon Clarke
  • 57 Answers
SOURCE: SYSTEM BOARD for HP Compaq Presario V2000 PC Notebook
HP are very good at supplying service manuals. However the one I have specifies part nos for Pentium M (373522-001)and Celeron M (373523-001)CPUs on the V2000
Posted on Sep 07, 2007
Benimur
Louie Role
  • 6966 Answers
SOURCE: car back up light switch
If you did not get a notice that somebody else was before you when you click on "POST", you were the first.
If you posted first and immaterial whether somebody elses posts after you and the user does not come back to review/rate/view, then you get the FixYa after 7 days;
If you posted first and then somebody else posted after you, your solution gets bumped down and the new gets #1.
Am not sure if FixYa changed the method, but the user can only view the 1st solution and will see the second if after he rates the first as a TFT.
Ganyan talaga una-unahan lang, minsan swertehan. Hindi mo masasabi na tama o angkop sagot mo. May pagkakataon mali nga ang sagot awarded pa rin or nauna ka nga pero mas pinili ng user yung iba.
Best is to provide a technically correct solution and then let it be.
Cheers.
Posted on Jul 30, 2008
Anonymous
SOURCE: I need the main input board
im looking for the same exact thing.
Posted on Aug 15, 2008
F1forHelp
  • 298 Answers
SOURCE: Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Posted on Mar 31, 2009
Anonymous
  • 70 Answers
SOURCE: Need instructions on how to dismantle a HP
open the scanner cover then look for the screw on the four corners of the unit i think only four screw you can dismantle it. You have to use T10 screw. if you remove the screw,lift up the scanner gently to avoid destroying the flex cable of the scanner that is connected to the logic board.Good luck..
Posted on Sep 10, 2009
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
There is no signal on my tv from my firestick
Make sure your firestick is plugged into an outlet. Make sure you change the input settings on your TV to access the firestick output.
May 06, 2017 | Televison & Video
I purchased a fire stick and I'm trying to hook it is to my tv I'm getting nothing should I still have my cable wire in my tv I have tried both ways and get nothin
Yes you can continue to use your cable. Firestick is connected to the HDMI port. You must have your tv source on HDMI to configure Firestick. Lastly, you must have a good wireless internet signal to setup Firestick.
Apr 21, 2017 | Televison & Video
Hi my firestick keeps losing wifi signal
This is almost certainly due to a weak WIFI signal.
Feb 22, 2017 | Computers & Internet
Mi motorola i833 is asking for a 8 digit code that i don't know
it was apparently loced by the previous owner, try 8 zeros.
May 05, 2010 | Motorola Mobility i833
My motorola i833 is asking for a special code it marks subsidy lock
https://www.fixya.com/support/r3664444-get_subsidy_unlocking_code_use_phone
Nov 17, 2009 | Motorola Mobility i833
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
