Do you mean the Vizio D32F-F1?
For any TV, first make sure that the current input is TV. For the D32F-F1, you can use the Input button on the back of the TV; it's the one at the bottom of the control buttons. There is also an Input button on the remote. Press the left/right arrow buttons or press the Input button repeatedly to navigate to the desired source. Press OK to change to this input.
Once the input is set to TV, press the Menu button. Navigate to the Channels menu item with the arrow keys and press OK. Highlight Find Channels and press OK. The manual for the Vizio D32-F1 is available on the product page: https://www.vizio.com/tvs/d32ff1.html . The current link to the manual is https://cdn.vizio.com/user-manual/PDF/2018/TV/D-Series_FHD_UM_ENG.pdf .
I hope this helps.
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
SOURCE: Trying to scan channels into my vizio, but no
I called my satellite provider. Problem solved!
SOURCE: No digital channels when scanning.
Do you remember to swith between cable and air in the set up manu? It needs to be at air position to have full scanning.
SOURCE: No channel programming scan, have antenna, no cable
There is, it's just burried in the setup menu.
SOURCE: how to recieve over the air channels on my vizio
No.You might not have a reliable service provider or you might just be in a area in which t.v. signals are hard and or impossilbe to recive.You might also have the cable box,or just cables,mixed up.Hope it helped.
