Refrigerators Logo
Posted on Sep 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Food in bottom compartment freezing food
Hello!! my question is why does the food in a GE hotpoint fridge freezing in the bottom compartment? to much stuff in freezer? or what can be causing this
merval1
Level 2:
  • Expert 70 Answers
  • Posted on Sep 18, 2009
merval1
Expert
Level 2:
Answers
70
Questions
Helped
19959
Points
209
You have the air flow regulator in the bottom of the fridge close to bottom compartment wide open experiment by closing it gradually till you have the desired result.
2helpful
2answers
Gfe29hsdss Is freezing food in fridg compartment & ice accumulated under the fresh food compartment
Food freezing in fresh food compartment is most likely a bad thermostat/ control board, or a damper that’s open too much.
2helpful
Our ge fridge is freezing food all over the lower fresh food compartment and the fan makes noise occasionally. does the fan need to be replaced?
the freezing on the lower fresh food area is some times caused by the freezer cold coil freezing up also caused fan noise .( that is where the fan is located . ) the heaters and tefroat terminator need too be ck and repalced if bad ..mm hope this helpt mm feed back pls ..
Ffa97 problems why is fridge compartment is freezing any food that is at the back
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
3helpful
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
1helpful
Food freezing in Hotpoint refridgerator
Hello, Your problem is going to be with your cold control/Thermostat this can be located in the control console inside the refridgerator. This part needs to be replaced, the part number is WR9X10042 Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike
1helpful
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
2helpful
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Top Refrigerators Experts
vince
Johnny 1000
