Question about Samsung Televison & Video
I have a 24 inch Samsung tv T240HD when I turn it on screen lights up bright but no picture, I can here the tv show, I hit menu no image ,the screen is lit up no picture, what can be the problem?
    Top Expert:
  • Samsung Master
  • 10,371 Answers
Check input or source settings if ok try picture settings
Posted on Oct 19, 2019
6ya staff
SOURCE:
nomn
  • 10 Answers
SOURCE: Sanyo DS24425 24" TV has great sound and no picture(black screen)
if TV have black screen,increase screen control to see vert amp IC is defective if you see one horizontal line in picture tube screen,and if screen is white with lots of line acrose ,you can find open resister,on picture tube board,or in main board near HV transformer.
Posted on Jan 26, 2008
Anonymous
  • 240 Answers
SOURCE: half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Posted on Jan 13, 2009
Ronnie Houston
  • 2920 Answers
SOURCE: double images
you will need to have the tv re converged to make the picture right call a repairman
Posted on Feb 16, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: No picture, no sound, green LCD light
Wow another Toshiba bites the dust! I am telling you from my expertise on toshiba that these people are having more problems then there worth to fix this your looking at $250 bucks justi n parts alone we not even talking labor. I worked on more TV's then computers now days. I would recommend not even trying to repare this unit. Find a sony and buy it. You be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
smbaby
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
I have plasma tv thats has been getting the pink bands across the screen when the image on screen is bright. It gets worse when cell light is turned up in addition to brightness.
You need to check all voltages there is a sticker on the back of the screen with various voltages these need checking with a digital meter.
Jan 06, 2016 | Samsung Series 5 51-inch PN51E530A3FXZA...
LN55C650L1FXZC no picture
Dim the lights in the room, turn on the set and shine a bright flash light on the screen. Do you see a faint picture on the screen?
Apr 07, 2013 | Samsung Touch of Color LN55C650L1FXZA...
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung T240 No Backlight
Look like your monitor is gone bad on you. I am not sure if you can get the parts you need. I would get another monitor form a friend and see if your monitor is gone bad. if it is I would get me a replacement. in the long run you will save some money.
Mar 24, 2012 | Samsung T240HD 24 LCD HDTV
Samsung t240hd, turn on, no picture, just sound. only had it less than a year! HELP!
did you find a solution? mine is the same. get a picture for about a second then it goes blank. it's not an input problem as it does the same whatever the source and you cannot bring up the menu on screen. audio works fine but no image after first second.
Apr 26, 2010 | Samsung T240HD 24 in. LCD TV
Suddenly no picture and no sound all three lights flashing
First make sure to hit the menu button on the TV's remote and if nothing is there then while the set is ON turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost of backlights is around 150.00 and power supplies around 100.00.
Mar 21, 2010 | Samsung DLP HL-P5663W 56" TV
I have a samsung hd crt that I bought in the US. I have it connected to my sky hd box but I will only show a 520 image and the image is offset. Why will not show a 720 image, without it being offset
Dear sir,
Here is the some settings for best view in Samsung HDTV
try this
Picture menu
Mode: Movie
Cell Light: 10
Contrast: 84
Brightness: 54
Sharpness: 0
Color: 54
Tint: G50/R50
Advanced settings submenu
Black tone: Off
Dynamic contrast: Off
Gamma: -1
Color space: Auto
Flesh tone: 0
Edge enhancement: Off
xvYCC: Off
Set the offset as per your requirement
White balance submenu
R-Offset: 24
G-Offset: 25
B-Offset: 25
R-Gain: 29
G-Gain: 20
B-Gain: 19
Picture options submenu
Color tone: Warm2
Digital NR: Off
HDMI black level: Normal [grayed out]
1080 Full HD Motion Demo: Off
Film mode: Auto1*
Blue only mode: Off
--Setup menu
Game Mode: Off
Energy saving: Off
i think it helped.
if you have any problem regarding this issue,leave a feedback we will glad to assist you
Have a nice day
good luck.
Sep 12, 2009 | Samsung Televison & Video
The image on the monitor is not crisp it seems to almost have a wavy effect
make sure you turn the sharpness control in the menu up to maximum.
Mar 30, 2009 | Samsung T240HD 24 in. LCD TV
Televison & Video Logo
19 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
