SOURCE: TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
SOURCE: 37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
Unplug and replug it...it should work eventually.
I have the same problem with my 32".
But it eventually goes on when i try it a couple of times (the number of times is completely random...sometimes none, and sometimes like, 3).
SOURCE: My Skyworth LCD TV 32
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
