Question about NordicTrack Exercise & Fitness
How to replace and adjust walking belt on Nordictrack NTTL99061
Most commonly at the end of the walking flat form. on both side end there are hex heads bolts that is what we use to adjust the belt on proper tension or tightness . and it could be use for keeping the walking belt in the middle of the flat form.
Posted on Oct 22, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: NordicTrack Exp 1000...stops after 40-55 minutes
My EXP000 is doing the same thing. But it is doing it when it is cold also.
http://sites.google.com/site/antiquebriggsandstratton/
Posted on Nov 18, 2009
Tim F
  • 103 Answers
SOURCE: Nordictrack EXP 1000 Treadmill Quits after 10 Minutes
Hello There, Thank you for all the information. It appears as if your walk belt is worn. What is happening is the friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside where the 2 blue wires go) When the belt wears the cloth on the underside becomes flattened out causing too much surface area to contact the walk board, thus the extra friction.
To check your walk board you can loosen the adjusting bolts on the rear and while lifting the walk board look underneath. If there is any wear/white areas then you will need to replace the board as well. You will be able to tell by just rubbing your hand across it and check for any places where the black film may be coming off.
Also the only time you really need to replace any of the rollers is when the bearings go bad or the pulley on the front roller separates. The rollers are about a 1% chance of causing this problem.
Good Luck! and great question, Tim
Posted on Feb 21, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: I have a NordicTrack EXP1000. The walking belt was
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
If their is still slippage then the drive belt will need to be adjusted.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Find the set bolt(s) on the motor.
This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt but do not remove.
The drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described above. Tighten the bolt and test. If the problem is not corrected, if problem persist replace drive belt
Posted on Jun 14, 2010
JIm Shipley
  • 218 Answers
SOURCE: I have a new NordicTrack
you will need to attach star washers to the rear roller bolts, they are having an issue with the lock washers they put on the rear roller bolts. Replace them with star washers. Tighten belt until it can be lifted about 2"-3" in the center.
Posted on Aug 12, 2010
boblilole
  • 13 Answers
SOURCE: walking belt on NordicTrack C1900 is to loose, how
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
Posted on Oct 03, 2010
I have a NordicTrack C2270 NTL12950. the belt is slipping. I have attempted to tighten it, but it seems to keep slipping. I would like to figure out if it is the walking belt or the drive motor belt.
if it's the walking belt, make sure that the rear roller is parallel to the back of the walking board. Sounds goofy, stand on the mill looking back away from the front of the display. Look down to where the walking belt goes around the roller, the roller should be parallel to the walking board.
Jan 09, 2018 | NordicTrack Exercise & Fitness
NordicTrack Treadmill Summit 5500 starts normally and runs about 5 minutes then stops, console lights remain on. Unplug safety key and plug back in, starts and runs another 5 minutes and stops ----.
there 3 things that you observe:
1) The walking belt is too Tight, the deflection will be 2-3" when you lift with his finger.Adjust the https://www.youtube.com/watch?v=XyPedy7HtzM
2) the thermic swithc of the motor Tripp for the tension of walking belt.
3)the driving belt of belt motor too tight. Deflection will be 1/8" loose the bolts of motor, and adjust.
Blessing.
cuadra2016@yandex.com
whatsApp:+50588611441
Oct 31, 2017 | NordicTrack Exercise & Fitness
I have a nordictrack a2350. The belt runs fine until you step on it. How do I fix this?
the walking belt may be loose. adjustment screws are at the back of the walking belt. one on either side
Mar 30, 2015 | NordicTrack Exercise & Fitness
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
Sep 30, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a NordicTrack EXP1000. The walking belt was so far to the left that the edge began to fray. So, I adjusted the belt towards the right and now it slips forward now and then when it gets up to 3mph or...
Jun 11, 2010 | Nordic Track Nordictrack Exp1000 Treadmill...
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feb 18, 2010 | NordicTrack Exercise & Fitness
Nordictrack EXP1000i stopped in the middle of program
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt. Good Luck, Tim
Nov 11, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top NordicTrack Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Kardoc
Steve P
Steve P
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
