Astra 2010 j series CD400 FM Radio stations won’t stay stored constantly having to retune .any ideas
6ya staff
SOURCE:
don mi4
SOURCE: phillips car 400 radio
Phillips car 400 -6 safe
Posted on Jun 04, 2008
jason
  • 905 Answers
SOURCE: FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Posted on Oct 06, 2008
gadgetmen53
SOURCE: How to test r/c transmitter for 27 & 49mhz using am or fm radio s
I went to wisegeek.com & they took care of problem & did not cost a penny. What happened to your site where it says Let our Expert solve your problem for FREE. Who wants to get advice from someone that does not know how to tell the truth & doesn't know right from wrong-Bye charlie lockhart
Posted on Jan 28, 2009
Anonymous
  • 580 Answers
SOURCE: Poor FM radio reception 2010 Prius
Check the antenna connection where it connects to the stereo it may be loose or not in all the way.
Posted on Aug 21, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: have lost all my favourite radio stations on honda jazz 2005 how do i retune ?
Select the AM or FM wave band.
Tune the radio to a station then press and hold down the 1 or 2 or 3 pre tune station button until it beeps. Then this radio station is then set to which pre tune button you have selected.
Repeat to set the buttons for other radio stations.
Posted on Aug 02, 2012
How to get radio stations to come in in my 2010 caravan
you have to set the stations if they come on at all and most set the channel by the search then just hold the number 1 button till it locks the station and so on
Mar 15, 2015 | 2010 Dodge Grand Caravan
I experience a problem with the unit in radio mode. When switched on the radio do not latch on the station (only background hiss) Only after repeatedly toggling the BAND button (random times)it will l
Try turning off the AutoTune (lock, center....) function (on most FM tuners) and retune manually to the errant station. Then reactivare auto-tune, or not. Toggling bands (as you put it) means that sometimes signal will center, sometimes not...a more or less random thing as you say. That suggests resetting station auto lock. Bear in mind though that certains stations can simply be uncooperative depending on numersou factors such as transmit location, reception terrain, and so on.
Oct 03, 2014 | Crosley CR7002A Turntable
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Have lost all my favourite radio stations on honda jazz 2005 how do i retune ?
Aug 01, 2012 | 2005 Honda Jazz
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
Hi i turn my alpine on and i have 2 retune the radio stations i store them but when i get back in my car i have 2 start 2 retune any idears
Probably you dont have the constant pos (+) wire hooked up to hot (+) wire and only to a source that is switched. Switched means every time your key is removed from ignition switch the positive current from that source will also power down. There are two positive leads from the unit, 1 always hot and the other needs to be switchable. The constant hot (usually yellow) powers the memory for your settings. Just like your television set, once you pull the cord off the socket everything returns to default setting.
Oct 20, 2009 | Alpine CDA-9857 CD Player
Aug 21, 2009 | 2009 Toyota Prius
Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Sep 16, 2008 | Pioneer DEH-1700 CD Player
Lodik dab 3006 radio
how to install a driver
Apr 30, 2008 | Computers & Internet
23 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
