SOURCE: staple gun specifications
Typical staple sizes are 1/4?, 5/16?, 3/8?, 1/2?, 9/16?, and 17/32? (6.4, 7.9, 9.5, 12.7, 14.3, 13.5 millimeters).
SOURCE: power shot stalel gun
there should be a silver clip thing thats over the mag that holds the staples try sliding that down and then it should open 4 you
PLZ RATE THIS IF U FIND IT HELPED YOU IN ANY WAY TANKS.
SOURCE: I have a power shot A5753 stapler where can I buy staples to fit
staples 10mm and 14mm can be bought at ;toolsandpartsdirect.co.uk
part no X70510 and X70514
good luck
ray
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
SOURCE: Cannot find staples for this
The ones you have are T-18 I believe
Fires 6 sizes of T50 type staples and drives 9/16 In. brad nails. Visual refill window and easy load chamber. Comfort grip.
•Uses Staples: PowerShot Staples, 97-010, 97-011, 97-012, 97-013, 97-014, 97-015, 97-030, 9/16 In.
•Brad nails
•Ceiltile 17/32 In., 9/16 In.
•T50 type staples, 505TML, 506TML, 508TML, 509, 50CT, 506SS, 504M, 505M, 506M, 508M, 509M, 504, 505, 506, 508, 509
•MFG Brand Name : Arrow Fastener
•MFG Model # : 5700
•MFG Part # : 5700
