Question about Teac Televison & Video
My new TEAC PC-D880 radio/cd player drains its batteries even when it's connected to a home power supply.
As far as I am aware, most units that operate from 220 volt DC as well as from batteries, disconnect the batteries automatically when connected to a mains outlet. However, this unit drains its batteries in no time even when connected to the mains meaning that it continues to draw power from the batteries even when this is not required. This is costly and is nuisance, having to remove the batteries every time when mains power is available.
6ya staff
SOURCE:
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: LG 42KK Power Supply Schematic Requested
you won't find any just ,
use a thermal probe or thermal gun as heat is likely the issue ,
if nothing else replace the main diode /rectifier and caps.
I find that if I replace the hottest items that usually the fix
if there is room for a small fan you will be doing them a great service and extend the life of the tv.
you may find some info on the power supply from one of these links they are generic enough
http://www.pacificdisplay.com/links.htm
Posted on Jun 10, 2008
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: Remove CD Magazine - No power to unit!
You will need to power the unit to eject the cartridge you only need a 12v source, any car battery etc. Then you just do it like you always do it. It is correct that it is not operating without power.
Wish there was an easier way for you, but hooking it up to power is not to difficult.
Good luck and if you need any other info on the device let me know,
Lee
Posted on Jun 15, 2008
drlalitv
Lalit Varadpande
  • 488 Answers
SOURCE: Power supply light LED turns RED.
the problem must be with the step down transformer,it must not be adequate for the xbox power needs..an option would be to buy a proper transformer from play-asia.com at http://www.play-asia.com/paOS-13-71-er-49-en-70-1pnk.html (i buy my games there,they are good)
which city are u from?perhaps i can find out where u can get the power brick..regards
Posted on Nov 22, 2008
Jesrey Paco-in
  • 91 Answers
SOURCE: Back UPS Model # BK200C salvageable?
Yes you right you can just use it as surge protector, but it would be better if you gonna buy a battery for that unit aleast you got a back up in the event of power outage.
Posted on Aug 14, 2009
Anonymous
SOURCE: Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Posted on Jan 09, 2010
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
Hi im driving 2007 toyota yaris,new,my battery was drained
The radios just plug in. Sounds like nightmare service to me.
Jun 30, 2009 | 2007 Toyota Yaris
Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Mar 14, 2009 | Teac PD-H300 CD Player
JVC drains battery when OFF, puzzling
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
Jan 12, 2009 | JVC KD-HDR1 CD Player
Question
I am 99% certain that it will only work with 'audio' discs. This is the case with my Philips CDR-796 and as far as I am aware applies to all consumer CD recorders.
Hope this helps
HifiJohn
Jan 04, 2009 | Teac CD-RW880 CD Player / Recorder
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
TEAC CD-P1260
Identical problem with my 4-month old player. I mailed the unit to the repair shop noted on their web page (Montebello, CA). They "re-soldered a loose connection" and made a "mechanical adjustment". I got the player back in two days. It now works fine (again). Under warrenty; no charge.
Jul 02, 2007 | Teac CD-P1260 CD Player
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
Televison & Video Logo
15 people viewed this question
Top Teac Televison & Video Experts
JOHN TOPLISS
Nidhish Ganga
Nidhish Ganga
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
