Dyson DC66 model vacuum
SOURCE: Dyson wand won't retract
I'm sorry to hear you're having difficulties with your Dyson's wand. Without knowing which model of Dyson you own, I'm unable to provide specific instructions. However, if you visit http://www.dyson.com and click 'Support', you should be able to identify your machine from the list. Our online Support guides should assist you in resolving this issue.
Alternatively, if you'd prefer to speak to one of our advisors, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
I hope this helps.
Best wishes,
Jack
Dyson Online Customer Support
SOURCE: my dyson just stopped running while vacuuming with
You probably got a blockage in your wand which caused it to overheat and cut out. Check for blockages, use a brush stale down the tube to dislodge anything. Next, check your filters, refer to the tutorials here: Looking after your Dyson.
SOURCE: I have a Dyson DC17 animal vacuuum. Recently got
you need to check the clean out ports 1 directly under the hose on the bottom and the other where the removable filter is
SOURCE: Cannot Assemble Dyson DC17
press the button on the side of the wand that detaches it from the main vacuum and try pushing it into the hose, let me know if this doesn't work
SOURCE: my dyson vacuum has no power.
Get an ohm meter (found on basically any multimeter), also called a continuency meter. its the setting that beeps when you have a straight line running from point a to b on a wire.
Unplug the vacuum. Test the cable from the plug to where it goes into the switch.Turn the switch on and test the points at the switch. Test the 2 wires running from the switch to the motor. make sure the 2 wires are plugged into the motor. Make sure the brushes on the motor is making contact with the armature. if they all test good, your motor has blown and will need replacing.
