Question about Garden
How do you hook the throttle linkage to a 2050 johnsered
2 Suggested Answers
Anonymous
SOURCE:
Ted Schore
  • 7353 Answers
SOURCE: need to hook up the throttle cables to the
Usually if you look at how they clip on to the bracket, they only go 1 way.
Posted on Dec 18, 2009
Carburator linkage
The governor link hooks on the top right of this carb and the throttle linkage is on the left all this is you standing in front of engine looking toward the steering wheel with the hood off
Sep 03, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Connecting carburetor to the throttle on husqvarna 44 chainsaw
The wire linkage has a short Z bend in one end this hooks into the throttle lever from the outside, the other end has a long loop this goes into the trigger arm from the outside, you will need to twist the top of the trigger arm slightly to allow the linkage to go into the hole in the trigger arm.
Dec 29, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Could some one tell us how the excelerator pump linkage on the float bowl side hooks up to the engine, that's a carburator for a 1968 chevy step van. the carburator is a rochester monjet # 7040021
Looking at an exploded view of your carburator in my Chilton book it would appear to me that the accelerator pump hooks to the throttle linkage on the opposite side from the throttle cable. On that end it shows a small plate that screws into the throttle shaft. This plate has 2 links attached to it, one of which should line up with a hole in the side of the main body. You will probably have to push the pump down by hand to line up the hole in the bottom of the pump arm with the hole in the body and attach the linkage.
There is no specific info in the book regarding this, just the diagram. Hope this helps.
Nov 11, 2009 | Chevrolet Chevy Cars & Trucks
1990 vulcan 750 throttle
no spring in the grip!
id suspect the cables are binding up inside so disconnect at the carby end then & see if they are moving freely
Cheers Rob
Aug 16, 2009 | 1990 kawasaki VN 750 Vulcan
Missing factory throttle linkages on 1990 YJ jeep. Need Diagram
Go to any scrapyard and you can get the entire setup for next to nothing...and you can see how it's hooked up!!!
Jul 07, 2009 | 1990 Jeep Wrangler
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
