Question about Delta Home
Delta steam iron I have a aldi delta steam iron which has suddenly stopped the pump is still trying to pump but no steam any suggestions please
6ya staff
SOURCE:
Anonymous
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
geokohler
George Kohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
Anonymous
SOURCE: I AM LOOKING FOR THE INSTRUCTION BOOKLET FOR A
looking for manual for delta nm902
Posted on Apr 28, 2010
Daniel Hebert
  • 102 Answers
SOURCE: 1983 Delta 88: how much MPG does a 1982 Oldsmobile delta 88 royal...
Personal experience between 13 - 20 for most models with the v-6 and v-8. the 5.7l is about the most fuel efficient at roughly 17
Posted on May 19, 2010
Linda Price
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
I HAVE A DELTA BAND SAW SERIAL# 102-3033 AND NEED PARTS
Find time to check www.bandsawparts.com . or give them a call perhaps.
Dec 04, 2012 | Delta Woodworking Delta Rockwell 14 Inch...
My team generator iron will not steam
Have you any other suggestions? Yes. Dump it.
Jul 16, 2017 | Morphy Richards Irons
Need manual for delta ultrasonic cleaner.....not in box when purchased from aldi
Hi.
Here all the documentation available on the web. If this is not enough contact Aldi to get a replacement booklet:
Model: 334.150
Data Sheet
Catalog Page
Model: 334.D80H
Data Sheet
Model: 334.010
Catalog Page
Data Sheet
Model: 334.080
Data Sheet
Catalog Page
Jun 10, 2011 | Vacuums
I have a Bosch Steam Generator Sensixx B25L that has suddenly stopped producing steam. The iron gets hot so that bit is ok, help, I have a huge pile of ironing!
Jun 01, 2011 | Irons
I have a Delta breadmaker BM900 bought from Aldi before Xmas. I have lost the paddle/kneading blade. The Aldi help line can'ty help and do not stock the item. They suggested I google ! I tried the american...
My kneading blade was also thrown out in a stale loaf when I had an unexpected hospital stay, Id only had the breadmaker a month- Ive tried the manufacturer an have been told they dont do any spares for that model, please post your solution if you are successful at tracking one down, thanks, Lorraine.
Feb 16, 2010 | Magic Chef CBM310 Bread Maker
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Jun 15, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Home Logo
32 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
mikenearman
Are you a Delta Home Expert? Answer questions, earn points and help others
