Question about Samsung Audio Players & Recorders
To remove protect mode on samsung model HT-C450
6ya staff
SOURCE:
John Weinreich
  • 336 Answers
SOURCE: sony ht-ddw750 protect mode on don't know why
Sorry for the bad news. It probably needs an output ic replaced.
Posted on Feb 23, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Anonymous
  • 56 Answers
SOURCE: powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Posted on Jul 02, 2009
SOURCE: SAMSUNG DIGITAL HOME CINEMA SYSTEM MODEL HT-Z110
Maybe the audio amplifier Ic are damaged and need to be replaced
Posted on Aug 14, 2009
Anonymous
  • 267 Answers
SOURCE: i have a samsung model ht-tz215/xeu dvd i switch
HI,
With regards to your recent query, when you
get a 'Protection' message on your unit it usually means the unit is
overheating. Please make sure there is nothing blocking the air vents on
the unit, nothing is sitting on top of the unit and that it is not near
any hot items like radiators. Please also check the cables that connect
the speakers, disconnect them all, reconnect, turn the unit off and back
on. If you have checked all of the above and the same thing still
happens, try resetting the unit, full instructions can be found in the
troubleshooting part of the user guide. Where did you purchase the
product?
ELSE
DO THIS
Pressing the STOP button on the front panel andholding it for 5 seconds". The power indicator flashes once and thesystem resets! wink.gif
Posted on Sep 27, 2009
Ah59 02291a remote wont connect to anything?
If your remote is a Samsung, it should be able to connect to your Samsung HT-C450. Although you say it has batteries in it, those batteries may be no good and fresh ones are needed. You need to determine whether your remote can be programmed to control your Toshiba TV. Instructions for using your remote could be useful for solving this problem.
May 12, 2014 | Samsung Audio Players & Recorders
Turn off protect mode
Probably power supply board. Remove and inspect for burns - front and back. Can be purchased for $50-60 on line. Google the part number.
Jan 13, 2013 | Samsung Ht-d5500 5.1 Channel Home Theater...
AH59-022914 no longer controls HT-C450
Try removal and reinstallation or replacement of batteries
Oct 29, 2012 | Samsung Televison & Video
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
My DVD HT-Q9
Bad speaker wiring.
Internal fault.
Regards.
Sep 23, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Samsug HT-SK5 fails with 'Protection' on display
Bad speaker wiring.
Internal fault.
Regards.
May 28, 2008 | Samsung HT-SK5 System
Protection Problem on Samsung Digital Home Theater
Bad speaker wiring.
Internal fault.
Regards.
Apr 14, 2008 | Samsung HT-DS610 System
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
