Question about In Office Equipment & Supplies
Bizhub 363 mode memory in saved image repeat 8copy
HOW DO YOU PREFORM F8 ON A BIZHUB 363 AND WHAT IS THAT FUNCTION..
Turn On main switch
Execute [Service Mode]---->[Imaging Process Adjustment]---->[TCR Sensor Adjustment]===>[Black]--->[Start]. Wait till it's stop [Exit]. Note : F8 is TCR Sensor Adjustment for Bizhub 363. Function : to set toner control / performs every time you replaced developer/developing unit.
Apr 02, 2018 | Office Equipment & Supplies
How to reset fusing in bizhub 363
go to service mode and in counters option clear the counter of fusing unit.it will reset.
Jan 12, 2014 | Konica Minolta Bizhub 362 Copier
Procedure For Installation Of Hard Disk In Bizhub 363
Procedure for Installation of Hard Disk in Konica Minolta bizhub 283/363/423 Photocopier Machines,
1-Get a SATA hard disk. NOTE: SATA HDD is supported in the above mentioned models. IDE or PATA are not supported.So get a SATA HDD.
SATA HDD have two main connectors. 1 is for Data and the other one is for power as shown in the image.Two separate cables are used.Data cable and the power cable.Get both the cables.Image of the cable is shown below.
bffe98cc-9b42-4878-b7d2-80a65e264546.jpgData Cable for SATA
107b626c-ac31-4927-b142-6dd8674309f2.pngPower cable for SATA Hard Disk
3-Connect the cables in their respective areas.
4-Now place the hard disk on its fitting. HDD mounting kit is fitted at the main control board of the machine.For this, open the back side cover of the machine and you will get the fitting.It will be on the main board in front of you. Now fit the HDD on its mounting and tight the four screws at its sides to keep HDD safe from shocks / jerks.
5-Now connect the data connector and the power connector to the control board.There will be two separate jacks for power connector and the data connector.
6-After fixing both the connectors to the main board, close the rear cover of machine with the screws.
7- Now turn the machine ON.
8-Go to the service mode and click on "SYSTEM 2"
9-Now click on "HDD" and select "ENABLE" and press "OK"
10-Now click on "state confirmation"
11-Select "HDD"
12-Now click on Format Hard disk.Select "Logical Format" not the physical format.Press "START" button and wait for few minutes.
13-When formatting is finished press "OK" and restart the machine.
14-Your new HDD installation is complete now and its ready to use for box operations.
Jan 12, 2014 | Minolta bizhub 250 Black and White Copier
Bizhub 363 error code c-fa16
MFPB board, but might try having a tech come and reflash the copier operating system software
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 16, 2013 | Konica Minolta Bizhub 363 Copier / Printer...
Bizhub 363 how to change developer unit
Requires having developer, drum, and cleaning blade already purchased. You will be taking the current cartridge apart and replacing the wore out parts then conducting required test, but before that it will require a drum dry procedure and counters to be cleared.
Mar 13, 2013 | Konica Minolta Bizhub 363 Copier / Printer...
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Feb 24, 2012 | Minolta Office Equipment & Supplies
Konica Minolta Bizhub 362: Any suggestions to the problem below? A very frustrating and error-prone device (in printer functionality). It's installed in a 20-user network who do use it lightly (total...
There is another solution but its more costly.All you have to do is to replace the parameter board of bizhub 362 with the board of 363 along with RAMs.
Mar 30, 2011 | Konica Minolta Bizhub 362 Copier
18 people viewed this question
Top In Office Equipment & Supplies Experts
Marvin
Marvin
Paul Carew
NatesGaga
Level 1 Expert
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
