Question about The Watches
I need to replace the battery in my LouisVuittion watch it is aLV2002 Z10962
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    How to open the back of Kenneth Cole KC3434 watch to change the battery?
    BASIC WATCH BATTERY CHANGE
    Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
    Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
    Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
    Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
    Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
    Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
    If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
    Best regards.
    Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
    I need a replacement battery for an original navy seal model (3000)? Does anyone know what type and size is in these watches? Other than sending it to luminox has anyone successfully found a replacement?...
    If anyone opted out to replace battery2_bing.gif in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries2_bing.gif, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help. In your particular case I do not see the reason why you should find the battery, because any decent watchmaker has many different batteries in stock. All you have to do is to find your closest watch repair shop and ask watchmaker to replace the battery. No need at all to send it to Luminox, as this job can be done at any watch workshop with the same precision and quality. In addition you will save money for shipping and pay less for battery itself.
    Rate me, plz.
    Jan 29, 2010 | Navy Seal Luminox Dive Watch
    How to replace battery in polar f4 watch
    HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
    Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
    How to replace battery for Timex expedition
    Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
    May 12, 2009 | Timex Expedition 84601 Wristwatch
    What's the replacement battery# for the Luminox 3000 Navy watch?
    I was shopping for one in Thailand and it was a GE 371. I did not replace it because they only carried the cheap china battery's.
    Mar 02, 2009 | Navy Seal Luminox Dive Watch
    Battery Replacement
    I thought you are supposed to touch the neg side of the battery
    Jun 01, 2008 | Casio DBC1501 Wrist Watch
    Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
    If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
    Apr 26, 2008 | Casio Atomic-Solar Watch GW300
    Watches Logo
    Top The Watches Experts
     Larry
    Larry
    vince
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a The Watch Expert? Answer questions, earn points and help others
