Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Try Platt Electrical supply - 800-257-5288 (Platt.com)BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help. Good Luck!
Remove vaccuum tube. Allow the access door for the vacuum tube to shut all the way. Attatch the blower tube where you had the collection back for the vaccuum attatched. That is it.
I disassembled the blower housing (orange). The switch is a momentary closed 2 position rocker (DPST?). Anyway, I sprayed electrical contact cleaner inside the switch as well as electrical lubricant. I also sprayed silicone on the convoluted switch linkage. That took care of the problem.
I posted this solution on another similar thread, but it may pertain here. I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
