SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
SOURCE: Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt.
Tearing the dryer apart is usually straight-forward enough but
stringing the new belt on the motor and idler pulley can be tricky. The
Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
SOURCE: I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
