Drills Logo
P
Pat mitchell Posted on Oct 16, 2019
Got 2 6095d drills. 1 has retaining screw,1 appears not.is possible? Re removing chuck
M J U
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 26, 2019
M J U
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1696
Points
7
Usually drill motors have a reverse (left) thread retaining screw located in the center of the chuck. The chuck however is typically threaded in the normal right hand configuration. Once the retaining screw is removed place a 1/4" allen wrench short end into the chuck and tighten, next strike the allen wrench with a soft tip mallot (counter clockwise while holding on to the drill motor firmly. This should loosen the chuck, then simply unscrew the chuck by hand. Good Luck!
5 Related Answers
Anonymous
  • 313 Answers
  • Posted on Jun 02, 2008
SOURCE: drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
stug_57u
Stuart
  • 99 Answers
  • Posted on Oct 25, 2008
SOURCE: drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Anonymous
  • 2176 Answers
  • Posted on Dec 31, 2008
SOURCE: Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Anonymous
  • Posted on Oct 18, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Anonymous
  • Posted on Oct 27, 2009
SOURCE: How to uninstall Portalign Precision Drill Guide
Put a suitable rod or even a large nail in the hole drilled through the shaft of the guide, and give it a sharp tap with a hammer so as to start it to turn in an ant-clockwise direction. You will then find that the guide can be simply unscrewed from your drill, and the chuck replaced onto it.
How do I remove the chuck retaining screw on my Ryobi power drill?
https://www.youtube.com/watch?v=TNegbb6pfBI
Jun 12, 2023 • Drills
6095d chuck, seems to have no retaining screw.is this a POSSIBILITY?
it is possible that a chuck is spun on if it has fine threads. most likely if the chuck is frozen you would have to use spanner on key hole and put the outer ring in a vise. It should loosen up. Sometimes I use a pipe wrench and the large channel locks to spin the chuck open. Most have a screw but it can get rounded over which would require drilling it out.
Oct 16, 2019 • Drills
CANNOT REMOVE CHUCK ON Makita DA3010F
To remove the chuck, unscrew the 4 screws that hold the chuck housing to the body of the drill. Put the chuck housing in a vise & remove the bearing retainer... it has a left hand thread, so righty loosey. Once the bearing retainer is out, the chuck slides out of the housing. Don't waste time looking for a screw because there isn't one.
2helpful
Need to know when removing a chuck from a drill is it clockwise or counterclockwise?
The retaining screw at the bottom of the chuck ( down inside where you put the drill bit) is reverse thread. the chuck itself is regular thread. Take out the retaining screw, chuck a 3/8 inch allen wrench ( short side) into the chuck just like a drill bit. Lay the drill down on a work bench with the chuck pointing towards you and the allen wrench clear of the table. Hit the allen wrench with a hammer, ( may take a few tries) in a counter clockwise direction. the chuck should unscrew.
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
What is the procedure for removing the chuck from a makita 6095D 9.6v drill?
Most chucks use a tapered shank that allows you to remove it with a good tap on the bottom. Other chucks have slots in the slots in the shaft that allows you to tao it off with a wedge type key. You could always use a dent puller and chusk on the screw.
Good luck, Jack
Aug 21, 2009 • Drills
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
2helpful
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
1helpful
I need to remove the chuck on my Bosch 33618 Brute cordless drill. How do I do it?
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
11helpful
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
