Sewing Machines Logo
Portia Preston Posted on Oct 16, 2019
Hi. I recently bought a Necchi Royal Series Model 3205 that didn't have a manual and I'm having trouble threading it correctly. Can anyone help?
Sam Guffey
Level 1:
Habit-Forming:
  • Contributor 51 Answers
  • Posted on Nov 03, 2019
Sam Guffey
Contributor
Level 1:
Habit-Forming:
Answers
51
Questions
0
Helped
10935
Points
95
If you do an internet search for "necchi 3205 threading" As an 'image', you will find many images with either the 3205 or other similar Necchi machines. I tried to upload an image to show you, but was unable to get it uploaded. But you will have no problem finding a detailed image online either of the 3205 or one that is very similar.
5 Related Answers
Anonymous
  • 323 Answers
  • Posted on Jan 03, 2009
SOURCE: I need to know how
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Anonymous
  • Posted on Jan 27, 2009
SOURCE: Necchi BU MIRA threading
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_BU_threading_Diagram.htm
this site has a picture
Anonymous
  • 255 Answers
  • Posted on Feb 17, 2010
SOURCE: Are there any directions or manual available for
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/3205_Instruction_Manual.htm
Happy Sewing!
Robbie
Anonymous
  • 41 Answers
  • Posted on Feb 26, 2010
SOURCE: Manual for Necchi Royal series model #3205FA
I could not find a free, PDF manual. But I did find this manual you could purchase for about 15 bucks.
Anonymous
  • 255 Answers
  • Posted on Mar 15, 2010
SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
1helpful
2answers
I bought a necchi royal series sewing machine at a garage sale it is practical new but there is no manual with it. can you send me one it's a model 4795
Fixya has no manuals or parts.
We are an question answering service for PRODUCT problems you might have.
Type your machine into your computer search engine and you should get some businesses that will be able to help you.
God bless your efforts.
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
6helpful
2answers
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Happy Sewing!
Robbie
1helpful
2answers
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
