Thermostats have multiple issues when you start checking them against thermometers.
1) the built-in thermometer may not match the set temperature because one or both need calibration. Compare the built-in to an external thermometer and see if there is any adjustment to make them match. Record the setting on the thermostat and the temperature when it starts and stops -- there should be a 1-3 degree range which may be adjustable. The set point should be in the middle of the on-off temperature spread.
2) the thermostat has a heat anticipator setting which may be set poorly -- turning off the heat before it reaches the set point - the fan normally runs for 1-2 minutes after the heat source is off. The anticipator is used to stop heating before reaching the set point as there are still a lot of BTUs coming out during the fan run-down -- usually 1-2 minutes.
SOURCE: heater blowing cold air
squeeze the hoses to get any air bubbles out and refill coolant as necesary. are you sure you put thermostat in the right way? may be backwards. also may be your sensor.
SOURCE: 2002 Lincoln Navigator. Heater is
try changing the thermostat if thats not it check and see if you have water leaking in the passenger side floor board if so then you need a new heater core
