hi u can use the master code to change ur security code back to whatever u like when the phone asks u for the security code simply enter the master code.the master code is specific to ur handset and is generated using the handset 15 digit IMEI no.the IMEI no. can generally be found beneath the battery of ur phone or type *#06# to view ur IMEI no.since u have given ur IMEI no.ur master code is 5767510316 type this code and reset ur security code enjoy was this useful if yes pls rate my solution
with warm regards-bonefirediv
Did you say you want to CHANGE your imei code, that is certainly IMPOSSIBLE... But if you want to CHECK you imei code, you can dial *#06# on you mobile phone and you will get the 15 digits number. GOODLUCK
this is your 10 digit master code.. keep is safe because this cant be changed, only security code can be changed. this code will work everywhr whr it asks for SECURITY CODE (ex keypad unlock with security code, reset phone to factory settings, etc.)
hi heres the code if you still need it write it down cuz youll need it when you change sim cards this code will only work with that imei number if you need code for other nokia post nother imei n i give you codes heres the code for the number you gave me its 1210630326 let me know how you get on
