Question about Panasonic Lands Phones
My Panasonic KX-TG785SK is stuck on Intercom and I can't seem to re set it so that I can make calls. all calls automatically busy out instantly.
6ya staff
SOURCE:
Anonymous
SOURCE: burst mode on Panasonic Lumix dmc-fx50
I have, after sifting through the 144-page manual, figured out what the problem is! At some point you must have set the "Auto-Bracket" setting to on - I did the same thing! To turn this off, put it in any of the Scene or Manual Exposure modes, then press the up (↑) key until "Auto-Bracket" comes up. Then, using the left or right (←,→) keys, set it to Zero (0). This should hopefully solve your problem! :)
Posted on Sep 19, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Posted on Oct 01, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
Posted on Feb 24, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Posted on Apr 23, 2010
Richard Van Brunt
  • 225 Answers
SOURCE: I have panasonic kx-t7730. How to set the intercom
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Posted on Dec 08, 2010
How to forward calls to another extension with panasonic kx-t7630
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
Do not know how to set the "ring over busy" feature on the panasonic KX-T7731
Panasonic calls that "call waiting". As answered previously, dial 7311# and 7321# on the intercom for a TA series system.
Carl
Aug 20, 2010 | Panasonic KX-T7731 Corded Phone
Everytime that anyone calls the receptionist, her line is busy, How do I correct this issue? Thank you . Panasonic KX-T7630
A couple of ideas. Have the receptionist call you and verify that they are really at the extension you're calling. Then make sure you turn on Call Waiting Intercom on that phone. From the intercom on the reception phone, dial *7311 for Intercom and *7321 for Outside lines.
Now the phone will soft ring and visual indication when you get a second call if you're phone is busy.
If you've mapped a button to ring the receptionist and it's not working, you may have unprogrammed the button. That's reprogrammed by PROGRAM, the button and 1 plus the extrension (usually 101) and STORE or ENTER to save. PROGRAM exits programming.
Carl
Jul 22, 2010 | Panasonic KX-T7630 Corded Phone
I have a Panasonic KX-T7456, calls to voicemail?
This is a giant guess because you may have a different system. Try dialing 7105 165 # from the intercom and try having someone call you.
If you have a Panasonic voice mail system, that's the code for call forward busy/no answer.
Your voice mail user's guide and system manual has the complete instructions.
Carl
Jul 13, 2010 | Panasonic KX-T7456 Corded Phone
How do I make calls go to voicemail both for N/A or busy for Panasonic KX-T7633?
If your voice mail extension is 500, then on the intercom dial *7105 500 #
Carl
Apr 22, 2010 | Panasonic KX-T7633 Corded Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
Panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
May 07, 2009 | Panasonic KX-T7633 Corded Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Panasonic kx-t7630
    i notice my Intercom Button flashes every 10 Minutes...how can i turn it off? Seems like My Intercom is calling my Co-Worker's Extension. Please advice. Thanks
    Jul 06, 2008 | Panasonic KX-T7630 Corded Phone
    Lands Phones Logo
    89 people viewed this question
    Top Panasonic Lands Phones Experts
    Ekse
    martin hogg
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
