Question about Panasonic Lands Phones
How do I unblock a number on my Panasonic KX-TS108W corded phone?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Posted on Feb 28, 2010
AndrexT
Andrew Taylor
  • 30403 Answers
SOURCE: Panasonic phone model kx-ts108w how to change emergency to a new number on this phone
Page 20 in the manual
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdf
PDF]Operating Instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdfIntegrated Telephone System. Model No. KX-TS108W. Pulse-or-tone dialing capability. Operating Instructions. Preparation. Basic Operation. Advanced Operation. Useful Information. PLEASE READ BEFORE USE AND SAVE. Panasonic World Wide Web address: http://www.panasonic.com for customers in the USA or ...
20
Storing Phone Numbers
You can store up to 20 phone numbers in the one-touch auto dial buttons
(10 numbers in UPPER memory locations, 10 numbers in LOWER
memory locations).
Make sure that a call is not put on hold.
To store in an UPPER memory location
It is recommended that you program an emergency number in the
EMERGENCY button.
Press
(PROGRAM)
Enter a phone number, up to 22 digits.
If you enter a wrong number, press
(PROGRAM)
and start again from step 1.
Press one of the one-touch auto dial
buttons.
A long beep sounds.
The unit will return to the standby mode.
If 3 beeps sound, the number entered in step 2 may be over 22 digits.
Press
(PROGRAM)
to return to the standby mode, and start again from
step 1.
If a pause is required for dialing, press
(PAUSE)
where needed. Pressing
(PAUSE)
counts as one digit (p. 24).
When using the Dial Lock (p. 27) or Call Restriction feature
Posted on May 01, 2018
20
memory locations).
EMERGENCY button.
Press
(PROGRAM)
(PROGRAM)
buttons.
A long beep sounds.
Press
(PROGRAM)
step 1.
(PAUSE)
(PAUSE)
May 01, 2018 | Panasonic Lands Phones
How can I unblock a number on the Panasonic kx-tg9331?
You can unblock a number by entering the Menu System and then going to the block call section. The fastest way is to press Menu then press # 2 1 7 . Then use the up/down arrows to highlight the number to unblock; then press Select (if Edit/erase aren't displayed). Use the appropriate soft key to select Erase. Then select Yes and press Select. Press Off to exit the menu system. See page 28 of the manual.
Panasonic has the manual on the product support page: http://shop.panasonic.com/support-only/KX-TG9331T.html . The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg9331_en_om.pdf .
I hope this helps.
Aug 03, 2017 | Panasonic Lands Phones
Manual for Panasonic model KX-TGF370 cordless phone
GO SEARCH IT ONLINE AND PRINT THE PDF . FREE
Jun 08, 2017 | Panasonic Lands Phones
How do I ubblock a number on model kx-GL430 a Panasonic cordless phone
How do I unblock a number from my blocked calls list? - Panasonic ...
eng.faq.panasonic.com/.../how-do-i-unblock-a-number-from-my-blocked-calls-list%3...
  1. Cached
To erase a number from your blocked calls list;. Press [MENU] [#] [2] [1] [7]; Press the [?] or the [?] button to select the telephone number that you want to erase. ubblock number on model kx GL430 Google Search
Dec 11, 2016 | Panasonic Lands Phones
same as before Eula
  1. Cached
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Mar 08, 2016 | Panasonic Lands Phones
I have the Panasonic KX-T7633 and when I dial a certain number is rings engaged and comes up with ACCNT - please how do I unblock this?
You don't. It's looking for an ACCOUNT number, which are assigned by the system manager. The number you have dialed is restricted by class of service. If you have a class override code, you can use that, or go to a different phone.
Apr 05, 2013 | Panasonic KX-T7633 Corded Phone
KX-T7433 - remove restriction
Google (Panasonic)(KX-T7453)(manual) without parens for instructions.
Mar 20, 2012 | Panasonic KX-T7453 Corded Phone
How do i delete speed dials on panasonic kx-t7730
since panasonic kx-t7730 does not have a delete option
we can however replace the number to a another number or a dummy number as per the model
KX-TA624 ....PRESS 2 *
KX-TA1232...PRESS 3 0
.... TYPE DESIRED NUMBER(eg: 0000)
AND HANDUP
This would replace the existing number
tell me if this works
Feb 24, 2010 | Panasonic KX-T7730 Corded Phone
Programe my phone KX-T7730
The phone you have (KX-T7730) requires a phone system to operate. This phone can be installed on a few different Panasonic phone systems. You need a "programming" manual for the phone system to do what you want (not a user guide) so you will first need to determine which system you have. Look for a part number on the system itself, it should start with "KXT" just like the phone.
Sep 16, 2007 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
66 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
