Question about Peavey Music
Our Peavey RQ2318 had the LED array of light for the L/R output go out. What do we do?
All of the clip lights are on even though nothing is plugged in to my peavey xr 8600
Something funky going on internally. Could be a power amplifier failure.
Jan 23, 2018 | Peavey Music
How do I fix my mixer 32fx out put
If the mixer output shuts down as you describe, some part is over heating and once it cools down you can turn it back until it happens again. This will not be user serviceable. Here is the link to Peavey Support who can provide a service center contact and schematics.
peavey com
May 21, 2016 | Peavey 32fx USB 32 Channel Mixer
I have a Peavey XR-600 PA Head, I would like to know if and how can I connect a MX 200 Dual Reverb Effects Processor to the PA Head?
If it has a effects loop output and input on the p.a. head and a in and out on the reverb effects processor, then yes you can, just run the effects loop output signal into the input on your reverb processor, out of the output back into the input effects loop on the p.a. head, kinda like you would a effects pedal thru the effects loop of a guitar amplifier. hope this helps!
Dec 02, 2015 | Peavey Music
How do I connect a peavey 32fx mixer to a peavey pv3800 ampflifier
You should be able to connect the XLR l&r outputs to the amp or the 1/4" l&r outs to the amp. Check out the manual here.
http://assets.peavey.com/literature/manuals/FX_Mixers.pdf http://assets.peavey.com/literature/manuals/FX_Mixers.pdf
Nov 03, 2015 | Peavey Music
How do I connect my Bose l1 compact to Peavey xr 8600?
You would come out of the Main output on the front of the mixer into the line in on the Bose.
You may find this site useful- L1 Unofficial Performers Guide
Jun 25, 2015 | Peavey XR 8600D Class D Powered Mixer
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
No output on the right side of the peavey 2600 amplifier but the right is ok
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Dan
Jul 15, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
54 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
