After battery replacement reset button will no longer set hands and dials to zero
SOURCE: tissot watch prs 516 automatic
I would recommend going to the following link and follow the instructions for resetting the counters and see if that corrects the issue.
http://www.tissot.ch/data/usersmanual/134-en.pdf
SOURCE: Hand on chrono won't reset to zero
It all depends on what kind of watch you have. On most watches you want to pull the stem out ( the part used to set the hands) HALF way, you will feel the "click" as you do this. Then I can't tell you which button ( because they are all differant on every watch) but one of the buttons will move the hand to the correct zeroing spot for you.
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
SOURCE: stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
SOURCE: how do I change the time on the tissot 1853 touch
Digital Watch
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
