Home Security Logo
Craig Parsons Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I install a mighty mule battery warmer (FM316) to a mighty mule gate system (562)?
Kenneth Simmons
Level 3:
  • Master 1,239 Answers
  • Posted on Oct 14, 2019
Kenneth Simmons
Master
Level 3:
Answers
1239
Questions
Helped
753292
Points
4061
5 Related Answers
Anonymous
  • 68 Answers
  • Posted on Jan 24, 2010
SOURCE: Schematic for mighty mule 502, lighting hit gate
Well this is a BAD situation, because your opener was NOT grounded, you will have to replace the Circuit board, but since this damage was caused by an act of god "nature, being lightning struck" Than GTO, "mighty mule" will probably NOT replace the board leaving you to BUY new ones, which are about $100 to $200
Anonymous
  • 68 Answers
SOURCE: I have a mighty mule gate opener model number 352
Check the STALL FORCE setting on BOTH openers, check for gate obstructions broken gate hardware. OR your limit settings have been erased, but if none are the problem that you have a broken REV COUNTER which is inside the arm
Anonymous
  • Posted on Apr 26, 2010
SOURCE: Mighty mule gate opener motor burned up after 2 years
Did you ever find a motor to fix the gate opener? I am looking for the same motor and would appreciate any help you can offer
Anonymous
  • Posted on Jul 07, 2010
SOURCE: Does anyone repair pc boards for the Mighty mule
I have used the Mighty Mule dual gate opener for 6+ years. The common failure is the relays. They are very inexpensive, less than $5 from Allied or Mouser, and easily replaced by any good electronic technician.
Might Mule will not sell the relays, only sells a reconditioned replacement circuit board for $250 - about half the cost of the whole system,
Anonymous
  • 68 Answers
  • Posted on Aug 10, 2010
SOURCE: How to use 2 button remote for two mighty mule gate openers
Chamberlain products do not support a 318Mhz frequency that gto uses, so that remote will not work unless you get a liftmaster receiver or any other one that it uses.
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
2answers
What is the best product to lubricate shaft on mighty mule gate opener
Lubriplate Low-temp Multi-purpose, Low Temperature Grease, the same grease used for Genie garage door openers. When i used other types of grease, the opener would squeal when the temperature was low.
Why is my mighty mule FM500 gate opener opening by itself?
Cathie,
Thank you for using GTO Products. If the gate opener appears to be opening by itself, then it's receiving an input from an accessory such as a transmitter, keypad, push button, exit wand, photo beam, loop detector, telephone entry system, etc.
By disconnecting these devices and reconnecting them back to the system one at a time, we can use a process of elimination to determine which device is causing the problem.
If you still need assistance, please call our tech support from the gate so we can help you troubleshoot. You can contact us at 800-543-1236 Monday - Friday from 8:00 AM to 6:50 PM EST
Technical Support
GTO Access Systems, LLC
2answers
Is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Its kinda hard but if you follow the info in the owners manual for your truck it works. It is not rolling code like a gargae door this is a dip switch on or off .
Mighty Mule 500 motor repair
Try Mouser.com part # P6KE16CA 36 cents a piece.
2answers
Does anyone repair pc boards for the Mighty mule gate openers?
Hello, im sorry to hear that you are having trouble with your gate opener. but it depends, on if your opener is still under warrenty and how the board got damaged, GTO "which is the manufacturer of mighty mule" is very picky about returning goods, so you MIGHT be able to get it replaced, but just getting it repaired is out of the question because of the components being heat sensitive and having software in the board, if you have more questions please email me a [email protected]
Schematic for mighty mule 502, lighting hit gate opener and now it does not work have replaced parts of foil runs and blown capaitor
6helpful
Gate open and beeping,it will not close
Well if your board is getting power and the power supply is ok, but when you try to activate the opener, and do not get a response, than you have a faulty board, im Guessing you have a GTO 1000, Mighty Mule 700, or Mighty Mule FM500 series
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
