Heating & Cooling Logo
David Byrnes Posted on Oct 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thermostat wiring connects between Temperature controller to HVAC. I got a new NEST thermostat and am not able to get it running right. The wiring show O and B wire conflict.
Old Thermostat show: E to AUX - loop, Y - yellow, G - Green, O - Orange, R - Red, B - White, Now on NEST, show O, and B on one slot. Which wire correctly connect?
AZBen
Level 3:
Sergeant:
  • Master 220 Answers
  • Posted on Oct 16, 2019
AZBen
Master
Level 3:
Sergeant:
Answers
220
Questions
0
Helped
80734
Points
1039
O and B are both for your reversing valve. Most thermostats have only one (Orange or Blue) wire instead of both. Because of this there should be a setting to select whether the wire will be powered for heat or powered for cooling. HVAC manufacturers used to select a default based on geography. In Northern climes they would use default to heat and in Southern climes they would default to cool. This saved wear on the solenoid and allowed the unit to function with a bad solenoid coil for the most frequent use (heat or cool). Lately the HVAC manufacturers do not base decisions on location or where it will be sold. So test your system and see if the O/B is energized when compared to the C (common or chassis ground at the 24vac transformer). Now check to see if you are getting hot air when set to heat, cold air when set to cool. If not then look in the thermostat setup guide to reverse the O/B function (change the default).
5 Related Answers
Ken Bledsoe
  • 306 Answers
  • Posted on Jan 16, 2009
SOURCE: I'm installing a Honeywell RTH7600B
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
A
Anonymous
  • Posted on Sep 28, 2008
SOURCE: Hunter 44100A programmable thermostat
Sorry Iasumed you had a heat pump t-stat. You will need to exchange to a heat pump t-stat
Anonymous
  • Posted on Jul 13, 2008
SOURCE: hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Anonymous
  • 828 Answers
  • Posted on May 22, 2008
SOURCE: heat strip install
What color wire is connected to the "Y" terminal on the thermostat.
If the unit you are connecting is a heat pump A/C unit the orange wire is for the heating mode. Normally the "Y" terminal on the thermostat. "R" terminal on the thermostat is the power to the thermostat, "W" terminal is for heating, "Y" is for cooling, and "G" terminal is for fan operation. At the condensing unit for cooling the brown and yellow wires would normally be for the cooling.
Anonymous
  • 44 Answers
  • Posted on Feb 09, 2008
SOURCE: how to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Nest Smart Thermostat battery keeps draining?
Ideas here
If you repeatedly get low battery messages from your thermostat, or if there's another power-related message, you may need to check the C wire connection or install a C wire to provide consistent power to your thermostat and prevent the backup batteries from draining.
Change Nest Thermostat batteries (Low battery message)
Google Help https://support.google.com > googlenest > answer
Answered: nest thermostat drains battery even with C wire
Google Nest Community https://www.googlenestcommunity.com > nest-thermo...
Nest thermostat has C wire, I verified using a multimeter that it has 24V. It still eats batteries every 2 weeks and gives a really annoying notification on ...
Fix: NEST Thermostat Battery Keeps Draining Quickly
Get Droid Tips https://www.getdroidtips.com > Common Problems
Jun 30, 2023 - How To Fix NEST Thermostat Battery Keeps Draining Quickly · Fix 1: Restart Your NEST Thermostat · Fix 2: Check The Wires · Fix 3: Check If It Is ...
How To Fix NEST Thermostat... · ‎Fix 1: Restart Your NEST...
My freestanding thermostat for on zone of my hot water baseboard heat is not working. I have replaced the batteries. will run once but will not keep running to reach the desired temperature.
There are several possible reasons why your freestanding thermostat for one zone of your hot water baseboard heat is not working properly, even after replacing the batteries:
  1. Wiring issues: Check the wiring connections between the thermostat and the heating system. Make sure that all wires are securely connected and not loose or frayed.
  2. Sensor issues: The thermostat may have a malfunctioning sensor that is not able to accurately read the room temperature.
  3. Mechanical issues: The thermostat may have a mechanical problem such as a faulty switch or a broken internal component.
  4. Compatibility issues: Make sure that the thermostat you are using is compatible with your hot water baseboard heating system.
  5. Incorrect settings: Make sure the thermostat is set to the correct temperature, and that the thermostat is in the right mode (heat or cool)
It's recommended to call a professional HVAC technician to diagnose the problem and provide a solution. If the thermostat is still under warranty, you may be able to get it repaired or replaced for free.
Thermostat for a Dayton model 2e441a
The Dayton model 2E441A is a belt drive direct drive fan and blower. It does not include a thermostat as it's a mechanical component that helps to move air. It is possible that you may have a thermostat that controls the temperature of the room or area where the Dayton model 2E441A is installed, but it would not be part of the Dayton model 2E441A itself.
If you're trying to control the temperature using this component, you may consider installing a separate thermostat that can be connected to your HVAC system. These thermostats can be set to a specific temperature and will turn the HVAC system on or off as needed to maintain that temperature.
It's important to note that you should consult a professional HVAC technician to properly install the thermostat and ensure that it is compatible with your HVAC system.
How to stop a thermostat from self setting
Different Nest thermostat models give you different options for setting up a temperature schedule that meets your needs:
  • Auto-Schedule (Nest Thermostat E and Nest Learning Thermostat only)
  • Basic Schedule (for Nest Thermostat E only)
  • Quick schedule (Nest Thermostat only)
3answers
How to fix a nest thermostat no power message
likely have a clogged drain line. Check your float switch.
2answers
I am trying to replace my Totaline P374-1000 thermostat with a Nest. The Nest needs 110 or 120 volt, but there is no sticker on the P374. Can you please tell me?
Your Totaline 374 almost certainly is running on 24 Volts transformed from somewhere near your furnace, boiler or a/c unit. You will probably need to find that and run new wiring for your NEST. I suggest you consult with a professional electrician or HVAC tech if you are not experienced in such things. Transformer probably looks like this:
1helpful
2answers
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
I installed a new thermostat on my hvac system and the heat is not working anymore.
On that thermostat there is an R and an RC wire connection, the R is the power wire for heat and RC is the power wire for cooling. If you connected the power wire (normally red in color) to the RC only the fan control and AC control will work, there has to be a jumper wire between the R and RC terminals (assuming there is only one control transformer) for both the heat and cool functions to work.
Kenmore Elite bottom freezer suddenly stops making ice.
hi The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Top Heating & Cooling Experts
Paul Carew
john h
