Question about Electrolux Kitchen Ranges
How to open top of Electrolux EL30ES55JSA to replace burner coil.
This model has the controls in the front and doesn't open like most glasstop ranges.
6ya staff
SOURCE:
BNewberry
Bill Newberry
  • 93 Answers
SOURCE: how do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Posted on Jan 10, 2009
Anonymous
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
Anonymous
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Anonymous
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Anonymous
SOURCE: Model RDSS30QW X-LO Burner Problem
remove 4 screws under the trim that surrounds the burner knob panel. They are on the underside and you will be looking straight up to see them.
Slide the trim down and off after removing the screws.
remove the burner grills and caps
remove the 4 brass venturis and you will then be able to lift the cooktop
the valves are easy to get to
Posted on Apr 24, 2009
I have a Maytag Glasstop stove (Mer5875qas). THe left front dual burner only heats on the outside ring. The inner portion does not heat. Could it be a wiring problem or is it more likely that the burner...
There are 2 likely causes. It is more likely that the element is open circuited and needs replacing. The hotplate controller could also be faulty. The circuit needs to be tested to determine the faulty part.
Feb 18, 2011 | Maytag MER5875QAS Electric Kitchen Range
Kenmore flat top range front burner popped and now doesn't heat.
Assuming the other other elements work....
Write down the entire model number and call a local Sears parts store if there is one near you. They should give you the option of having the parts shipped or picking it up.
To change the element:
Unplug/turn power off to your range first.
Look under the front lip you should see between 2-4 screws. Remove the screws and then the glasstop will lift up. You might need some help to hold it up while you remove the front support bracket.
Once you have that bracket removed from the glasstop, you can change the bad element.
Dec 29, 2009 | Kitchen Ranges
Glasstop heating coil replacement
To remove the top,open the oven door and the screws for the top are located on the top of the door opening,remove the screws and the top will open,then you will see 2 screws that hold each element in place,just remove the one not working.
Aug 08, 2009 | Frigidaire FEF366 Electric Kitchen Range
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
How do you replace a burner switch on a Frigedaire Glasstop Stove
Thanks Again,
Bill
Jan 10, 2009 | Frigidaire FEF366DC Electric Kitchen Range
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 | Cooktops
Lifting the glass top to replace elements
I removed 2 screws under the front edge when you open the oven door
Apr 01, 2008 | Frigidaire FEF366 Electric Kitchen Range
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
54 people viewed this question
Top Electrolux Kitchen Ranges Experts
Marvin
Marvin
Eric Rotmil
Eric Rotmil
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
