E1 erro code on, sinotech washmachine
Wash machine does not drain
6ya staff
SOURCE:
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: E1 fault code Dishwasher runs for
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Posted on Aug 05, 2009
Anonymous
  • 1738 Answers
SOURCE: error e1. washing machine will not drain
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Posted on Aug 10, 2009
Anonymous
SOURCE: e1 flashing on my telman washing machine
I found my manuel. It means somethngs stuck in the pump or pipes
Posted on Dec 04, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: I have a Baumatic integrated
Hi.
E1 in Baumatic washing machine is Leakage error.
In your case, if you have a BDW13, then we are talking about an integrated dishwasher, not about a washing machine.
On the BDW13 control (and on all Baumatic dishwashers), E1 message means Long fill error. The error is prompted when a water inlet problem is encountered.
The first thing to do is moving the appliance, and checking hoses and faucets at the back.
If hoses are OK, then the inlet valve and water level switch must be tested.
Inlet valve is tested reading impedance at valve solenoid contacts. If the valve is working OK, and the machine is filling, then the water level switch must be tested.
Some Baumatic also have a controlled fill that uses a reservoir, in case that must also be checked.
Most of the time the problem is caused by a kinked hose at the back of the appliance, move the dishwasher out and have a look.
Remember to disconnect power before doing any operation.
Regards.
Ginko.
Posted on Oct 18, 2010
caroldon
  • 17130 Answers
SOURCE: my roper washmachine will not
It is so common that the drain cloggs and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. The dain pump /valve must be tested and if fault must be replaced.
Posted on May 18, 2011
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Washer stops after first wash cycle and wont drain
ge spacemaker spinner in washmachine isn't moving and making noise
Dec 30, 2009 | GE Washing Machines
E1 flashing on my telman washing machine
Dec 03, 2009 | Washing Machines
E1 fault code Dishwasher runs for about 5 minutes. Water fills up at bottom of unit and then machine seems to pause then fault code E1 appears then water is pumped out from bottom of machine. There are...
Aug 05, 2009 | Dishwashers
E1 Error code - no leaks - new pump - new pc board in Dec. 09
The most common reason for an E1 error on an LD dishwasher (that does not have a leak, including directly under the dishwasher) is the drain hose between the dishwasher and the drain does not have a rise in it between the DW and the drain. Either install a proper AirGar valve or attach the hose to the bottom of the counter top so that it raises 30" between the DW and the drain. When that raise does not exist, the laws of physics tell you that you WILL have a siphoning effect from the DW into the drain, causing the LG to report error code "E1", which is true because of the water leaving the DW during all the wash and drain cycles.
Good Luck!
Apr 03, 2009 | Dishwashers
Calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
