Question about LG Dishwashers
I am trying to remove my LG dish washer filter. It is stuck. How do I get it out.
Dish washer has water in bottom & double beeps when trying to start
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 06, 2011 | LG 24 in. LD-12BW5 Free-standing...
Filter needs cleaning. How do I get at the filter?
Dishwasher filters are important to catch food particles and other debris. The dishwasher cleans small portions of food from the dishes, cooking pans and silverware. These particles must go somewhere. The drainage system on the washer may clog if filters are not present. Most Maytag dishwasher models have two types of filters, "Coarse" and "Fine." You should clean the "Coarse" filter after two or three wash loads. The "Fine" filter can wait for a cleaning for about 300 loads or three months.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Sink sponge
  1. Empty the dishwasher. Remove all dishes including pots, pans and silverware.
  2. Pull the bottom rack out as far as possible. The filters are under the basket on the Maytag dishwashers. It may be convenient to lift the rack out. Typically, if you lift, the wheels leave the track.
  3. Remove the "Coarse" filter. This filter is a small, round knob in the middle of the "Fine" filter. A round knob is around the "Coarse" filter. Hold on to the handle and lift straight up.
  4. Knock the contents of the "Coarse" filter into the garbage can. Run the faucet to remove smaller particles. Wipe the dishwasher filter with the sink sponge if debris is stuck-on. Push back into the filter holder when complete.
  5. Take out the "Fine" filter. Turn the round knob that is around the "Coarse" filter counter-clockwise. Once the knob is loose, pull up. The "Fine" filter will come out of the dishwasher.
  6. Rinse the "Fine" filter with the hot water faucet. Scrub with the sink sponge to remove any stuck-on fragments. Replace the filter into the dishwasher. Push down and turn the knob clockwise to tighten.
Jan 09, 2011 | Dishwashers
Food always gets stuck in the water spray holes pluging them up. It needs a better food filter system. We have a GLD4500N
As recommended most of the dishwashers are not equipped with this filter. But it is always recommended to clear the food off the dish/plates, wash off or wipe and put it for cleaning. The dish washer cleaning is entirely the degreasing/ sterilising of the vessels.
Hence the tip to get your dish washer in good shape is to wipe/wash off the food and load it to the trays inside.
This is my suggestion as we cannot improvise the machine. I hope this helps Good day
Aug 18, 2010 | GE 24 in. GLD6300L Built-in Dishwasher
LG washer with OE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 27, 2010 | LG WM-2277HW Front Load Washer
White film left on dishes and dirt still on silverware
There are 3 standard answers to solving the white-deposits-on -dishes problem: 1) Use a rinse aid; 2) use less detergent; 3) use vinegar in the washer. If you have hard water, none of these may work, especially if you've had the problem for a while. Because phosphates were ordered removed from dishwasher detergents, hard water minerals can now react with the soap to create a heavy greasy-feeling scum. That scum can build up in the water lines, arms, bottom reservoir, and filter, providing an endless supply of goo to spray on your dishes. This can be fixed. You need to remove and clean out the spray arms, the filters, and especially the array of parts at the bottom of the tub. I've seen up to 1 cup of coagulated/crystallized scum in the bottom of dishwasher tubs. Once you clean out the scum, then run the washer empty with a completely full detergent cup on the highest temperature setting, extra rinse. Before you start it add to the detergent cup 1 teaspoon of TSP(tri-sodium phosphate), a very powerful phosphate cleaner available at hardware stores. Your washer will now have all scum gone from the inner workings. From now on you must always fill both your detergent and pre-wash cups to the max and use a high temperature water setting, extra rinse. Chemically what you're trying to do is adding so much detergent that the scum-forming reaction is overwhelmed by the dispersant action of the detergent, and the extra heat helps this to be more effective. I am not a fan of vinegar in the wash cycle. Why? In some washers the vinegar fumes can reach the exposed contacts of the printed circuit board or touch pad, corrode them, and then your washer won't work at all, along with being very expensive to fix.
May 14, 2010 | LG LDF6810ST Stainless Steel Built-in...
Not getting dishes clean
Hard to believe but you have to clean the dishwasher. There are various screens and baskets down in the bottom of the dishwasher. Take out the rolling bottom dish rack and you will find the first layer of filter there. Usually there is a handle on it lift or turn and lift that whole rig out and wash the basket and all the filters. There even may be a second layer of filter below that. Then check down in the the very bottom for chunks of stuff or even broken glass. Now the spinner. There is a spinning water sprayer that can also get gunk stuck inside it.. I found rice in mine. There should be a click lock or some kind of release tabs on the side of the shaft. remove that sprayer and look closely at the water jets to see if stuff is in there. run some water thru it too make sure the jets are open. lastly.. you must run the dish washer every day. if you leave them there over night you will need a jack hammer to remove the dried food. Some dried food like egg yolk will never come off in a dish washer.
Dec 13, 2009 | Dishwashers
LG DISH WASHER LE CODE 4th.TIME
Have your service tech remove the door cover and check the wiring harness completely. Especially where it flexes at the bottom. LG had a problem on some of these models with the insulation degrading on the wirw. Replace the wiring harness and the motor again.
Oct 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dirty dishes on lower rack
Please confirm that you own an LG LDF7811 dishwasher and it is not cleaning properly.
-Are you getting any error codes displayed? -Did you remove the mesh filter and clean any debris beneath it plus rinse out the filter itself?
-Are you using a name brand diswashing powder? Avoid ultra-cheap detergent, especially in water-conserving units like the LG 7811. Never use DW gel or tablets in any dishwasher.
-Do not over rinse the dishes before placing them in the DW. The food granules actually are used to clean all the dishes before being rinsed away.
Please try these suggestions and reply to this message with what worked best and if the problem continues. Good Luck!
Aug 25, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
