Previously for several years, I had never removed Disk from camera.How to recover pictures from Disk? Could I do it without camera with same additional device?
Is this an SD card or SDHC card ? If so, have you inadvertently set the write-protect switch to 'ON' ?
To read it on your computer, you will need to get a USB card reader that will read your particular card, then connect this to your computer, which should treat the card as an extra drive.
You say the card has been in use for several years - it may just be corrupted or at the end of its useful life - I should consider replacing it soon.
Testimonial: "Thank you. The card is SD. I hope I did not inadvertently set the write-protect switch to 'ON'. If I did, what does it mean?"
It means the card cannot be written to, but this is easily remedied. With the card label facing you, contacts at the top, on the left side there is a little switch. Move it down for write protect, up to free card for writing. Good luck.
Thank you very much. Unfortunately, I could not find any switch on the left side. May by disc is too old. It's written sanDisk Ultra II 4GB CF 2004. What to do? How to recover pictures?
SOURCE: CARD FULL with 3 pictures
I'm assuming you are NOT on macro settings, right? and, is it possible that those are movie clips, instead?
SOURCE: write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
SOURCE: Olympus 790SW 7.1 MP reads full 1GB memory card is full after 2 pictures
Suggestion is to format the memory card and permanently delete all of the images from it. The card should then be able to be reused and you can start taking images again. To format the card go to Menu - setup and press ok - go to format and press ok - go to yes and press Ok. This will clear the card and you are back in business.
SOURCE: Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
SOURCE: unable to get pictures from camera to pc
Olympus Master 2 software download snippet
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
This is a free download therefore no serial key is needed.
