Question about Ted Baker Watches
I can't get the back back on my Ted Baker ladies watch after changing the battery
    Top Expert:
  • Ted Baker Master
  • 54,966 Answers
Align the slot in the back with the stem, then press firmly.
Posted on Oct 13, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: watch
I would recommend you to go to a Juwelry, or a watchmaker and let him put the plate back on it. They might do it for free, or it will cost you 3-5 euros/dollars, nothing much;)
Posted on Jun 26, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how can you get into a sovereign ladies watch to
You have to pull stem out of watch movement completely and then remove watch glass. Sovereign watch cases are monoblock, so, the only way to get into it is to remove the glass. Rate me, plz.
Posted on Feb 10, 2010
Testimonial: "thanks, the watch seems to be made to look like the back is separate, does the stem just pull out. it only seems to come out about 3mm.thanks"
arbie herrera
  • 125 Answers
SOURCE: how to change battery on a ladies classic 18 k and
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Posted on Feb 22, 2011
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do I remove the
After removing all screws you have to use fine pointed tweezers and pry up watch case back using them. Insert between case and case back and pry up using lever action.
Posted on Apr 04, 2011
bigdawg7299
  • 2559 Answers
SOURCE: How can I change the battery on a ladies Sekonda 4602AKT watch.
If it is indeed a screw type back it will have indentions ON the back (6 to 8). A special tool is required to remove the back without damage to the watch back. Any reputable jewelry store should be able to remove the back. If there are no indentions then it should be a pop back. Some watches do not have a slot to slide a pry tool under the back. You have to use a sharp knife..taking appropriate safety precautions.
Posted on Jul 04, 2016
Ted Baker watch 10030650
The Ted Baker manual is said on the manufacturer web site to not be available online. It instructs you to contact them by phone or email.
Email us at customerservice@genevawg.com or call 800-874-0907
https://www.genevawatchgroup.com/instruction-manuals
Aug 04, 2018 | Ted Baker Watches
Need to change battery in Armitron Now ladies watch 75/2475. How to do it. How to you remove the back on the now 75/2475 watch
Take your Armitron watch to a jeweler for a demonstration of how to open it. While there, you may be able to persuade the jeweler to install a replacement battery, all for a reasonable sum.
Feb 10, 2018 | Armitron Watches
How do u change the battery in a gossip small ladies watch
  • Remove back
  • Locate battery and note how it is installed
  • Identify battery
  • Obtain replacement battery
  • Remove old battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set functions
  • Return to small lady
Oct 14, 2016 | The Watches
Removing back of irish collection ladies watch for new battery
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
https://www.youtube.com/watch?v=L4Y7pDonkmk
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...Missing: irish
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
https://www.youtube.com/watch?v=gFmV7NIjVsw
Sep 1, 2011 - Uploaded by RichsMethods
I also show how to polish the metal portions of your watch. ... of how not to take the back off and remove ...Missing: irish
Dec 21, 2015 | DG Watches
How do i change the battery of a Bulova 96L37 watch
take it to walmart and let them do it . of any god watch shop . you need a case press to put it back together without breaking the front crystal
Feb 14, 2015 | Bulova Watch
Changing battery on TE4027 watch
Pl don't try yourself better visit a well experienced watch maker to replace it otherwise you will finish with worse
Jun 23, 2012 | Ted Baker TE4027 Watch
Just purchased a gold ladies 1928 watch. No instruction manual with it. Is it a manual windup or battery operated watch? Need instruction manual or booklet also.
Hello Ted,
Can you please specify the the Brand and Model of the watch? If you don't know it, just specify all the markings you can read from the watch.
Thanks.
I'll be waiting for your reply.
Nov 16, 2011 | Watches
My dkny ladies watch stops when I take it off. After resetting and putting back on, it works again. Why does it do this?
mcdevito75 here, It"s possible the battery could be so ever slightly loose, or the battery could be weak and need changeing. Also possible, the quartz mechanism could be going bad and movement of the watch while wearing it keeps it going, with the watch off your wrist and at rest, it's just to weak to keep moving on it"s own. Best Bet is to look for a small watch repair shop in your area and have them check out your watch.
Aug 22, 2010 | DKNY Modern Edge Lady Watch # NY3901
Watches Logo
56 people viewed this question
Top Ted Baker Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Ted Baker Watch Expert? Answer questions, earn points and help others
