Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to get the date on the actual picture and when I scroll to date stamp it jumps over it and won't let me set it.
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Sep 18, 2009
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
951072
Points
10742
In order to turn on the date stamp, the camera needs to be in 'postcard' on the resolution setting. Press the Func/Set button, scroll down to the resolution (L, M1, M2, M3, S, Postcard), then scroll over to the postcard icon and press the Func/Set button again.
I HAVE A CANON POWER SHOT A610 AND I DONT KNOW HOW TO DATE STAMP MY PICTURES. PLEASE HELP
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again.
Feb 05, 2011 • Cameras
I newly bought a Canon EOS Rebel T2i camera; I read manual a few times, I can't find how to stamp a data in the picture to show the date I took the picture. Could someone tell me how to do that, I am sure...
3helpful
Cannot get the pictures to keep date and time on them
2helpful
I want to switch off the date stamp in my pictures taken with A480, please.
Press Menu, scroll down to "Date stamp" and across to select off, date or date and time, then press menu again. The date stamp only works in Postcard mode, so if you set a different picture resolution, that will also stop the pictures being date stamped.
How do I get the date/time stamp to show up on the picture file on my cyber shot DSC W80. Help!! Thanks Darren
6helpful
How to add time and date to a 10M or 6M pictures, seems
Sorry, don't know why Canon designed it this way, but it is only possible in "Postcard" resolution. This is true for all Canon models.
For those wishing to set their camera to include Date/Time stamp on the photos:
As mentioned, the date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
16helpful
I CAN'T GET THE DATE TO TURN ON. IT WILL LET ME RESET IT, BUT IT WON'T LET ME TURN IT ON. When I go into the menu setting, it shows that the date is turned off and I can not access another menu that will...
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
1helpful
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
13helpful
2answers
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
2helpful
2answers
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
