Per nozzle check all colors except 3eBK and second 6C print horizontal lines. The color intensity is the same for the duplicated test elements. 6BK seems light. Several cleanings and several deep cleanings make no difference. Ink cartridges have been replaced but this started happening before replacing cartridges.
You need a new printhead,QY6-0049-000, around $50.00.
Testimonial: "Exactly what was needed. Thanks"
The following a step by step instructions for the printer issue:
Certain colors are missing or no ink prints on the paper
snap in ink tanks properly iP4000 / iP5000
Install recommended ink tanks in the correct order iP4000/iP5000
Perform deep print head cleaning (Windows) iP3000/iP4000/iP5000 by using the software not manual cleaning.
Remove tape from the ink tank … check ink tank vent hole the ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
Replace ink tank
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
